engine ping
Old Nov 10, 2005 | 10:13 PM
pageparsley's Avatar
pageparsley
engine ping
ive got a new 5.0 crate engine with a holley 600 and aod tranny.when i get on the gas hard the engine makes knock or ping like sound. or if im in like third gear and give alot of gas the same.could it be air fuel mixture float bowl level or fuel pressure. any input is appreciated. thanks
Old Nov 10, 2005 | 10:41 PM
budman-mo's Avatar
budman-mo
Lean fuel will ping (low float or possibly low pressure) If it's instant it's probably not the pressure.
Vacuum leaks are the easiest cause (hoses or intake / carb base gaskets) Too hot of a spark plug can do it too.
Timing advanced too far.
Does it have normal or high compression ratio?
Old Nov 10, 2005 | 11:18 PM
pageparsley
engine ping
it has normal compression. ill try out what you suggested tomorrow. thank you very much
Old Nov 11, 2005 | 08:19 AM
Kemicalburns's Avatar
Kemicalburns
timing would be my first guess then carb adjustments from there.
Old Nov 13, 2005 | 02:44 PM
'92FlareSide's Avatar
'92FlareSide
That is what my truck is also doing, so i put in 93 octane it worked than i put in 87 and it is back and seems like it is doing it even more than before. I have a 92 f150 w/302. WHY???
Old Nov 14, 2005 | 05:36 AM
ken75ranger's Avatar
ken75ranger
I'm with Kemicalburns. Try timing, carb then an intake leak. I found a nice trick for intake leaks. Use brakecleaner to spray the bolts., If you have a leak it will make the exhaust smoke.
Old Nov 14, 2005 | 09:09 AM
Kemicalburns
92flare, check your timing. it should be set at 10*btdc with spout connector removed. it is very important to have the rig at running temp. once you have set timing and checked it. reconnect spout and start it . then turn off and unplug battery for 15mins. then reconnect and drive for 30-45mins. do some city/hwy driving at various speeds this helps the ecu relearn. also if you are due for a tune up by some seafoam and run that thru before changing your plugs out. once this has been done scan for codes
have fun
Old Nov 14, 2005 | 09:44 AM
budman-mo's Avatar
budman-mo
As for the brake clean trick, I always used carb cleaner. If it sucks it in it will change enging speed. You just have to be sure that all your air intake system is on and it's not just picking up the fumes through the air filter.
Old Nov 15, 2005 | 04:17 PM
'92FlareSide
Ok, I will try that out. Thanks
sudsmcduff
Jan 12, 2016 06:24 AM
mystic201
Modular V10 (6.8l)
Nov 22, 2015 06:29 PM
geoaigel
1978 - 1996 Big Bronco
19
Nov 5, 2008 06:17 PM
Eric K
Modular V10 (6.8l)
126
Apr 20, 2008 12:35 AM
t4kne
15
Apr 5, 2007 09:15 PM
