Balancing issue...
Old Nov 10, 2005 | 11:09 PM
Muldo's Avatar
Muldo
Balancing issue...
G'day folks, long time, no talk, but right to the nitty gritty here:
Building a 331 out of my 302, bought a kit that requires a 28/28 imbalance, dampener and flexplate. Not too tough, except for one thing.
I've got an E4OD.
The dampener is easy, I can buy one new if I have to, but the flexplate, ahh the flexplate. Where to find? There are days I wish I had a AOD or C6....but alas.
I know 351's kept the 28 oz imbalance, and plenty of those came with E4ODs, but will that flexplate bolt up to my 302/331 crank and work with the stock starter location etc.
Or, can an older 302/C6 flexplate do the trick? (This question is based on a couple of other threads that I've read, as well as some possibly misleading info elsewhere on the 'net.)
My understanding is that an incorrect flexplate will displace the torque converter into the transmission, tearing it all to heck, starting with the pump. I don't want this.
Lets stop there and see where this goes.
Bring it on.
Mike
Old Nov 11, 2005 | 08:16 AM
ken75ranger's Avatar
ken75ranger
You have 2 choices.
Get your flexplate rebalanced. Not always easy to find a shop to do it.
The 351 flex plate should work. It will definately bolt up. I'm not sure on the tooth count. You could bring your's with you for comparing it. They should be the same size, holes, and tooth count with a smaller weight.
Old Nov 11, 2005 | 08:58 AM
Muldo's Avatar
Muldo
I believe that my flexplate is a 164 tooth count, so as long as the one I find from a 351 has the same, I oughta be okay. That sounds good.
I can get my flexplate rebalanced, but I'd like to leave that as a last resort. My truck is still running and I'm building a second motor, so I'd prefer to have ALL of the stock equipment available for installation if need be...
Mike
Old Nov 15, 2005 | 12:29 PM
Muldo's Avatar
Muldo
Nobody else has any thoughts?
Old Nov 15, 2005 | 04:11 PM
Kemicalburns's Avatar
Kemicalburns
the 5.8 flexplate will work. no worries
Old Nov 15, 2005 | 06:43 PM
Muldo's Avatar
Muldo
Coo...thanks.
Brown Falcon
17
Aug 10, 2011 04:22 PM
Bigdaddybendog
May 28, 2010 01:31 AM
linckeil
Apr 27, 2006 08:46 PM
RaleighDad66
Jul 7, 2005 09:29 PM
