Modular V10 (6.8l)
2010 pinging
Old Oct 30, 2015 | 06:40 PM
mystic201's Avatar
mystic201
2010 pinging
I bought this truck new. It has 69000 mi. and just started pinging. When I really step on it will down shift but it will not up shift till I let off the gas. It has no power and really pings. Any help would be greatly appreciated. I am running an SCT tuner set to 87oct performance tune for fuel mi. Thanks Jeff.
Old Oct 30, 2015 | 09:11 PM
Bigdawg5565's Avatar
Bigdawg5565
You're not the first to have this issue with your truck. You need to read this thread: https://www.ford-trucks.com/forums/1...0-pinging.html
I think perhaps it might be a good idea to pin this thread for a while. I have had another thread where this problem came up and it has to do with catalytic converters getting plugged up. Check your VIN for a recall notice with your cats. Now you may have another issue going on so I suggest you do your own due diligence. If your truck comes back with a catalytic converter recall notice you can take your truck to a ford dealer and have them test your cats. Now if your cats are not plugged you will be billed for the service obviously and I'm betting it will be a couple of hundred dollars, but I suspect you may have the same problem I have had and a few others have had so again please do your own due diligence and be as certain as you can before your start chucking out $$ chasing the wrong problem. Good luck and keep us informed here.
Old Oct 30, 2015 | 09:13 PM
Bigdawg5565
Another thread to check out: https://www.ford-trucks.com/forums/1...loss-miss.html
Old Oct 31, 2015 | 04:47 AM
Im50fast's Avatar
Im50fast
I don't know anything about the recall, but I know I had the same problem with mine. There's another thread or two that I researched greatly and added quite a bit to them with my experience.
The post above mine suggest you go to a Ford dealer. I would suggest checking it yourself first. Take the Y pipe loose at the engine, and look inside there with a flashlight or small camera. It should be a perfectly nice looking honeycomb structure. If not-game over.
Old Oct 31, 2015 | 08:10 PM
fbergski's Avatar
fbergski
My 2004 F250 V10 CC auto pings when I tow my toyhauler. I read about the converter issued but solved the pinging by running premium fuel when I tow. Run 87 octane when not towing and it runs fine.
Old Nov 3, 2015 | 12:00 PM
mystic201's Avatar
mystic201
well I took the the dealer and it is what we suspected the cats and y pipe. They want to re-flash my computer after installing new parts I guess I should un load the 5star tune and re-install factory tune ? I have 2 days till parts come in advice needed thanks Jeff
Old Nov 9, 2015 | 04:36 PM
zapola6's Avatar
zapola6
My cat was bad and clogged....
https://www.ford-trucks.com/forums/1...converter.html
Old Nov 16, 2015 | 01:11 AM
twigsV10's Avatar
twigsV10
Good advice.... Did you by chance try the oxygen sensor mod? I'm curious if it works on the other vehicles or if it's a fluke on my Mustang????
Old Nov 16, 2015 | 03:35 AM
Im50fast's Avatar
Im50fast
I have not. But I've wanted to really bad. The exhaust smell is pretty bad. Also I feel like it doesn't quite have as much power as it used to. Not sure if that's due to CEL/Fuel air ratio, or my 230,000mile spark plugs or other lack of maintenance.
Old Nov 18, 2015 | 02:23 PM
Bigdawg5565
The dealer also re-flashed my computer too. How is your truck dong with the new cats?
Old Nov 22, 2015 | 06:29 PM
4x4pwr's Avatar
4x4pwr
Also, if you haven't already I would suggest doing like I did in this video. Common problem with these V10's.
DieselBill
6.7L Power Stroke Diesel
May 4, 2013 03:29 PM
FordGuy0131
Jan 16, 2009 05:10 PM
