Bed swap
Old Mar 27, 2002 | 07:31 AM
Blaine's Avatar
Blaine
Bed swap
Old Mar 27, 2002 | 10:10 AM
chris28's Avatar
chris28
Bed swap
Sorry to post two different times but I also have a question on swapping beds. Will a 79 long bed fit on a 76 long bed? Are there any major differences? Thanks in advance!
Old Mar 27, 2002 | 11:22 AM
Vampiro's Avatar
Vampiro
Bed swap
no there are no differences. as long as everything matches upi it'll work. 73-79 parts are interchangeable since there from the same ares
Old Mar 27, 2002 | 12:11 PM
78f250boy's Avatar
78f250boy
Bed swap
they are the exact same for the yrs. 73-79. i still am looking for beds for my truck. but the thing is i would like a tool box, and a dual tank long bed. any info where i could find one?
Old Mar 27, 2002 | 02:58 PM
fordguy76's Avatar
fordguy76
Bed swap
the only difference is the gas filler hole and neck. the one on the 77-79 has a square door and the 73-76 has a round hole with a screw on cap. the filler hose is different too. the one from the 77-79 has a better angle on it and will take gas better
Old Mar 27, 2002 | 05:23 PM
chris28's Avatar
chris28
Bed swap
Mine has dual tanks on it and the one I plan to swap has a single any ideas on how I might could work that? The bed I have is a flat bed with two side boxes on it with dual tanks. If the swap works out then I won't be needed that heavy thing.
Old Mar 27, 2002 | 09:18 PM
Scouder's Avatar
Scouder
Bed swap
If you are going from a 79 to a TWO WHEEL DRIVE 76 it will fit. If you are talking about an F-250 the bolt holes will NOT line up. The F-250 has a narrower frame and will require you to drill new holes in the bed. Im not sure about the F-150 4x4. Other than the holes it will fit fine.
-Scouder
Old Mar 28, 2002 | 01:40 AM
tetraruby's Avatar
tetraruby
Bed swap
There's a bed on Ebay search: "1979 Ford truck". The seller has the applicable years...sounds like the previous post - 2WD...
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
