Has anyone had a Powertrax no slip installed on there F250 with a 10.5 rear axle. I ordered mine and it should be here Friday. Just wondering if this is something I can install or should have it done?
CmprSpecial
Called richmond and they said its the same as the 2000 10.5
billbain
How does the truck perform? Do you notice it locking and unlocking? It is suppose to be quieter then a lock rite.
I helped put one in an older jeep, but that didn't require removing the carrier.
I guess I have the lockright, the cheaper one that doesn't require the carrier to be removed, just replaces the spiders. Works fine, don't notice much noise.
