Aerostar Ford Aerostar
How to remove steering wheel?
Old Nov 10, 2005 | 04:28 AM
Pablo-UA's Avatar
Pablo-UA
Yesterday I tried to remoove steering wheel. It is not positioned correctly...
I concidered this procedure to be easy before.
I tried to loosen bolt. Well, sucsessfully. But when I tried to pull the steering wheel away, It did not move!
I TRIED TO PULL IT WITH EXTREME FORCE!
NO RESULT!
How to remove It. May be to use special tools
Old Nov 10, 2005 | 11:05 AM
bertha66's Avatar
bertha66
You will need a steeringwheel puller. It bolts into the two holes next to the steering shalt and the center stud of the puller pushes down on the shaft. Something to think about, the front end maybe out of alignment and a alignment shop can center the wheel with a ajustment.
Old Nov 11, 2005 | 04:09 AM
x.l.r.8's Avatar
x.l.r.8
If you do carry on trying to pull it remember if the wheel flies off, what is it going to hit first, I put my tooth through my bottom lip doing exactly that, now I use a rubber mallet and it will come off, nothing special about the wheel, it's just been on there some time.
Old Nov 12, 2005 | 12:50 PM
Pablo-UA's Avatar
Pablo-UA
Ok! I will try to nock It by hummer throught a piece of wood... About the center bolt: I will do only 2 turns CCW. It shold limit wheel's fly... Unfortunatly I have no puller, can you give me its picture...
By the way, my friend put the steering wheel on his neck and couldn't take it away, so we had to cut it.... It is not kidding.... Bu we had a good lough.
Old Nov 12, 2005 | 03:23 PM
93nighthawk's Avatar
93nighthawk
What was your friend doing to get his head stuck in the steering wheel?
And it sounds like one of those "funniest home movie" moments.
Old Nov 12, 2005 | 09:46 PM
xuzme720's Avatar
xuzme720
I've heard of heads getting stuck under the steering wheel, but thats a topic for another forum.
Old Nov 13, 2005 | 12:24 AM
copper_90680's Avatar
copper_90680
Oh Xuzme, you have been reading the "Big-uns" again, haven't you
Old Nov 13, 2005 | 08:18 AM
Pablo-UA's Avatar
Pablo-UA
It was a steering wheel of Tavria '92... He wanted to remove a steering wheel...
It was really funny, but my friend was very upset and angry.... Just Imagine how his wife was looking at him with steering wheel on his neck!
Old Nov 13, 2005 | 09:03 AM
xuzme720's Avatar
xuzme720
I would have loved to see his face as he tried to explain just how he got into that predicament(sp?) to her.
Old Nov 13, 2005 | 01:31 PM
krankshaft's Avatar
krankshaft
Here is a helpful link on how to use the steering wheel puller the instructions are for a Honda Accord but the use of the puller is the same.
http://www.filtsai.com/accord/steering_wheel/index.php
You can rent a puller for free at your local Autozone or you can buy your own I bought mine off e-bay from the seller issof1 for $24.99 + shipping pictured below.
I bought it because it included all the different size and length bolts so in addition to steering wheels I can pull harmonic balancers and crankshaft pulleys as well.
fullsleeves2
Sep 5, 2025 09:03 PM
f-150 hot rod
1997 - 2003 F150
Dec 27, 2020 11:09 PM
eman92082
Jan 3, 2008 07:55 PM
xnman
Aug 17, 2007 10:46 PM
302FORDF100
Jun 20, 2005 11:09 PM
