Sponsored by: Auxito
intermediate steering shaft removal
Old Dec 4, 2004 | 12:28 PM
f-150 hot rod's Avatar
f-150 hot rod
My 98 f-150 the other day developed a clunk/rattle when turning the wheel and going slow over bumps. Today i checked the steering shaft and can move it up and down quite a bit. What is the repair for this, new shaft? If so, how much is a new shaft? Also, what are the steps for replacing one of these? Thanks for any advice.
Old Dec 5, 2004 | 11:38 AM
Racerguy's Avatar
Racerguy
The shaft is pretty easy to replace.
Under the dash there is 1 pinch bolt and under the hood at the steering box is another. Slide the dust boot off of the steering box where the shaft goes on to access the bolt. Just slide it up the shaft. Then the shaft slides together at the slip yoke to shorten it up enough to remove it. The boot where the shaft goes through the firewall can be a bit sticky sometimes but it just pulls out. Make sure when you install the new shaft that the boot goes the whole way into the firewall like it should. You'll see how it locks in. Don't let the steering wheel turn when you have the shaft removed. If the steering wheel turns more than a couple revolutions it will break the clockspring in behind the wheel.
I'm not sure of the cost of the shaft.
Old Dec 5, 2004 | 10:05 PM
f-150 hot rod
Thanks for the reply Dave.
Old Jan 8, 2005 | 11:17 PM
f-150 hot rod
noise fixed
I finally got around to replacing my intermediate steering shaft in my truck today, been busy with holidays and everything. Clunk noise is now gone, the cost of the new shaft was about 60 dollars.
Old Jan 8, 2005 | 11:22 PM
Racerguy's Avatar
Racerguy
Good to hear that you got it fixed
Old Dec 20, 2020 | 12:51 AM
Arambu74's Avatar
Arambu74
Wow thanks for the clear directions
my husband and I are really impressed with the easy clear cut directions you gave!
Old Dec 20, 2020 | 01:14 AM
Racerguy's Avatar
Racerguy
Thanks
Old Dec 27, 2020 | 06:25 PM
newfordy's Avatar
newfordy
I was impressed as well, the fleet shop where i used to work did a lot of these. You get a clunking at idle when in a full lock turn.
If I may add one tip - to keep the steering wheel from turning just link it to the turn signal or shift lever with a loop of electrical tape. It won't be on long enough to leave residue and the stretchiness will allow some flexibility
Old Dec 27, 2020 | 11:09 PM
Racerguy's Avatar
Racerguy
Good tip !
77highboy400
17
Nov 21, 2022 01:46 PM
OL FLATTOP
Mar 23, 2015 03:28 PM
shrekau
Mar 23, 2014 12:44 PM
Dirrttym
Nov 1, 2012 02:59 PM
donship
Computer Chips & Tuners
Feb 6, 2007 11:28 PM
