stroke and bore
Old Nov 9, 2005 | 08:54 PM
chrono4's Avatar
chrono4
stroke and bore
whats the biggest youve ever heard of a a 460 being stoked and bored to? just kinda curious, cause i heard some crazy numbers, just want to see if there relistic.
Old Nov 10, 2005 | 07:37 AM
greenhighboy's Avatar
greenhighboy
There are some guys on another forum that have built 600" motors with a stock block. With an aftermarket tall deck block you can go 800" plus.
Old Nov 10, 2005 | 08:14 AM
fordman300's Avatar
fordman300
you can go 4.75 stroke and bore whatever the block can take on a stock block. at .060 over that gives you 583 cubes
Old Nov 10, 2005 | 10:55 AM
monsterbaby's Avatar
monsterbaby
the 600+ cid engines almost always require the use of sleeves, yes you can run 4.75 stroke crank personally I don't like it do to rod ratios, and where the pin has to be in the piston. Also 4.75" stroke cranks are always expensive since from what I have seen the only way to get them at this time is a billet crank which runs pretty close to $3000 and atleast $2500 so why would you put a 2500+ crank into a $50 junk yard block?
Realistically in a stock block with sonic testing, and without using sleeves 557 si probably you max although if you sonic test, and sleeve the one or two thin cyl a 572 (4.5x4.5) is pretty doable.
Using an eliminator premier block with a max bore of 4.7, and a 4.5 crank your at 624, and go with the 4.75 crank your at 659cid.
Kaase runs the alum tall deck blocks to build his 815cid prostock engines but not only are they tall deck but they are 5" bore centerlines instead of 4.9"
Old Nov 10, 2005 | 12:21 PM
chrono4's Avatar
chrono4
man, they can really get up there then. thanks for all the replies.
1972RedNeck
Nov 25, 2012 03:27 PM
PowerstrokeRyan
20
Aug 21, 2011 01:48 PM
redzepp35
New Member Introductions
Sep 15, 2006 04:22 AM
65f100CoryE.
Feb 2, 2005 09:21 PM
vulcan22255
Dec 15, 2004 11:53 AM
