sun pro tach
Old Nov 11, 2005 | 08:03 AM
motohead121's Avatar
motohead121
Post sun pro tach
i need some wiring directions on a sunpro tach my frend gave me the tack and lost the directions to hook it up so i was wondeing if any 1 can help me i have 4 wires red,black,green,white im asuming red is hot and black is ground what about white and green im instaling it on a 1995 ford f150 302 thanks
Old Nov 11, 2005 | 08:06 AM
frederic's Avatar
frederic
Red - ignition
black - ground
white - illumination
green - tach input
Old Nov 11, 2005 | 09:18 AM
motohead121
Exclamation sun pro tach
ok so red goes to the ignition black is ground white i can prob hook that into the dash lights and green were should that hook to
Old Nov 11, 2005 | 10:02 AM
frederic's Avatar
frederic
The ignition coil.
Old Nov 11, 2005 | 12:14 PM
motohead121
ok theres 3 wires going into the igniton 2 above 1 below should i tap into 1 of those
Old Nov 11, 2005 | 12:36 PM
pfogle's Avatar
pfogle
Hook the red wire to a switched source that come on with the key. The white one hooks to the dash illumination, the black one is a ground, and the green one goes to the same wire on the coil that has the condensor/noise suppressor hooked to it.
Old Nov 12, 2005 | 09:09 AM
motohead121
Thumbs up sun pro
i got in hooked up thanks guys it looks pimp
yankeerebel
Nov 30, 2016 05:42 PM
Gunnerboy
May 22, 2016 10:03 AM
Unaffiliated
Mar 31, 2016 10:31 AM
Rockworthy
Aug 15, 2015 09:24 PM
oft
Apr 24, 2002 09:12 AM
