86 ranger 4x4 ?
Old Nov 7, 2005 | 05:40 PM
ford784x4's Avatar
ford784x4
86 ranger 4x4 ?
i just got a 86 ranger short bed 4x4 STX,2.9,5 SPD. WHEN I PUT IT IN 4WD IT MAKES A LOUD BANG SOMETIMES ? MABY THE AUTO HUBS? CAN YOU CHANGE THAM TO MANUEL HUBS? DOES ANY ONE KNOW WHAT THE SXT PACKEGE IS? THANKS
Old Nov 7, 2005 | 06:10 PM
93STX's Avatar
93STX
I have been told it stands for sport trax weather its true or not i am not sure
Old Nov 7, 2005 | 07:48 PM
ford784x4's Avatar
ford784x4
will the truck have a dana 28 or 35?
Old Nov 7, 2005 | 08:25 PM
frankenbroncoII's Avatar
frankenbroncoII
dana 28. is the "bang" coming from the front of the truck or under you butt lol (tcase)?
Old Nov 7, 2005 | 08:27 PM
frankenbroncoII
the stx is a trim package and a suspension package (shocks, springs, and sway-bar combination that only came on the stx unless you ordered it) though dont quote me on this
Old Nov 8, 2005 | 08:43 AM
sublimecharger68's Avatar
sublimecharger68
yes you can change the auto to manual hubs,
Or you can pull the auto hub off and dig out all the old grease and add new grease and you might get lucky and it will work fine.
The STX Package was made to compete with the Chevy S10 Baja, to have a sport Ford Ranger, you got Better Shocks, springs Etc, like mentioned already and then the Graphics on the Side. Also you could get a Factory Brush Guard, Roll Bar With Lights and a rear Tube Bumper. In 88 they Also Made STX High Rider that had a 1.5" factory Lift installed only avaible in the Standard Cab Ranger though.
good luck sublime out.
Old Nov 8, 2005 | 08:51 AM
sublimecharger68
there is a swap from auto to manual here,
http://www.shockersgarage.com/Autohubswap.html
also the STX Package was made to compete with the Chevy S10 Baja, to offer a ford ranger Sport Model, you got the better Shocks, Springs, Etc already mentioned, and had the options of a factory Brush Guard and Roll Bar with lights if you wanted. also a 2 tube's style rear bumper. and the Graphics on the side. In 88 the Ford also made a High Rider STX Option on the regular Cab rangers that had a factory 1.5" lift installed
hope this helps you out, also you might get away with just taking the auto hubs off removing all the old grease and adding new grease might also solve your problem.
good luck
Old Nov 8, 2005 | 06:46 PM
ford784x4's Avatar
ford784x4
thanks for the info. it looks like someone took off the brush gaurd and the roll bar.i will try to clean out the hubs before i change them.
Old Nov 8, 2005 | 06:48 PM
ford784x4's Avatar
ford784x4
the bang is comeing form under the cab.
Old Nov 8, 2005 | 09:49 PM
frankenbroncoII
check the fluid lvl in the tcase. it may be low, or the tcase could be on its way out
reamer
27
Aug 3, 2009 08:40 PM
klassik1
Apr 18, 2005 10:33 PM
IB Tim
Bronco II
20
Feb 13, 2004 08:02 AM
jaman
1978 - 1996 Big Bronco
Jan 12, 2002 11:55 AM
