Serial Port COM1
Serial IRQ : 4
Serial addresses : 3f8-3ff
Serial Uart Chip no: 16550 FIFO
Serial Port COM2
Serial IRQ : 3
Serial addresses : 2f8-2ff
Floppy Disabled?: No
IRQ: 6
DMA channel: 2
Pointing Device: PS/2
Ptr num buttons: 2
SCSI Disabled?: No
SCSI Chip Mfg: Adaptec
SCSI Chip Model: 7880P
num of SCSI channels: 2
SCSI IRQ: 14
SCSI Memory start: c8000
SCSI IO start: 0f800
Video Disabled?: No
Video Chip Mfg: ATI
Video Chip Model: Mach 64 VT2
Video colors: 256 (8 bit)
Video res: 800x600
Video Mem: 1 MB
Video Memory start: c0000
Video IO start: 0f400
Add-in Cards, Boards, and Adapters
Add-in Board Vendor: Intel
Model : EtherExpressPro 100B
Board Type: Ethernet
Type: Single I/O
Located in slot num: 1
Bus Type: PCI
Bus Master Board?: Yes
Ether IRQ: 9
Ether IO start: .
Ether IO end : .
Device descriptions
Disk Manufacturer: Seagate
Disk Model : ST32550N
Disk Interface : SCSI
Disk Capacity : 2 gig
At least with the age of microchips they was able to get away from the vaccuum tubes they had in the computer center at MSU which filled the whole first floor and had as much power as a current laptop.
I know I am dating myself, but I worked on one of the first of the vacuum tube computers, the Univac Model 1. The drum memories were as big as 55 gal. oil drums.
*****I use Internet Explorer and the "Back" button and spellcheck icon (a check mark) have disappeared. Anybody else have that problem or suggestions?
Dono
First computer I used was in 1969. IBM 1130.
Ah, the days of Alpha-numeric keypunch machines, circuit boards and jumpers, sorters and rooms had to be kept at a chilly 68-70°.
(I don't remember hardly anything about 'em. CRS settin' in.)
Then on to 8088s w/MFM HDDs, 286s, 386-DX40, 486-DX2/80, PIII - 90mhz 733MB HDD, w/8 megs of RAM. RAM was expensive back then (1995). $384 for 8 megs.
Now look at the prices.
Dono
For the "Back" button, try clicking "View" on the menu or right clicking on the IE tool bar and make sure "Standard Buttons" is checked. The Spell check sounds like a Google tool bar...? If so check under options on the Google tool bar.
good luck
LOL.....I took Computer Programming in 1969-1970. IBM punchcards/Fortran. The "future" was 12 inch disks.
My mother was a secretary for Rohr Aircraft in the early 60s but wanted to be an Engineer as her father was. Took the new computer programming courses at night to get out of the secretarial pool into Stress Analyst/engineering. Worked on Gemini and the early Apollo programs.
RAND "Home Computer" by in the year 2004 (!) as envisioned in 1954.
1954 Popular Mechanics Magazine: Scientists from the RAND Corporation have created this model to illustrate how a "home computer" could look like in the year 2004. However the needed technology will not be economically feasible for the average home. Also the scientists readily admit that the computer will require not yet invented technology to actually work, but 50 years from now scientific progress is expected to solve these problems. With teletype interface and the Fortran language, the computer will be easy to use.
In 1975, this was the first commercial "computer" game!
While living up at the mine, our neighbors had an early cell phone in their truck about 1978. The husband drove a truck for a local contract company when not mining. The horn would go off to notify them a call came in.
But by 1983, we oldsters should remember the Commodore64 Personal Computer with 64k RAM.
Hummm... & to think I started on Commidor and an Atari...
BIG step up was IBM 8086 with 2 5.25" floppy disk drives & NO HDD Wopping 64k of Mem.
My first HDD was a huge 10 Meg that NO ONE could EVER fill up.
That was an "Intel" 8086. I took the 'Machine level language' course on that one and the 8080 and 8080-A. Those were all Intel chips. That was in the 70's, before I ever heard about IBM getting into the small signal devices.
I worked on a Tube type machine that had 8 rows of 8 tubes. Imagine that, 64 Bits of storage. One row was the shift register.
At one time there were over 200 computer manufacturers in the US.
the power edge 2100 is a pro 200 mhz machine, it came with a 4.2 gig hard drive. yes it may be scsi! i see scsi everyday as i work on PC's and Sun systems and find SCSI to be quite common.
p.s. i was working on machines back in the CPM/80 days. before the advent of DOS and windows.
