Quick question on divorced NP205
Old Nov 5, 2005 | 05:24 PM
AnOldDog's Avatar
AnOldDog
Quick question.
This is a 1973 Highboy that my son and I have been resurrecting from the dead. It is now just back to drivable, but the T-case is swinging forward and back, knocking against a cross member. My question is this...
Is this simply a matter of replacing the bushings and retorqueing and rewiring the top castle nuts, or is there another bracket (that doesn't seem to exist on this truck) that controls for and aft movement?
Old Nov 6, 2005 | 11:31 PM
hotroddually's Avatar
hotroddually
some trucks were equipped with a support rod that was attached at the bottom of the t case and the truck frame cross member,but not all divorced cases had them.(mine does not have it) i would try to tighten the mounting bolts ,and if that doesnt fix it,then replace the bushings,and then tighten it all back up.the lack of a support brace shouldnt matter.as i said,they didnt all come with them,so its up to you if you want to add it or not.ive never had one and i dont see the need to put one on my truck.-billy
Old Nov 6, 2005 | 11:52 PM
AnOldDog's Avatar
AnOldDog
Thanks, I saw the support rod in the factory manual, but there is a gas tank in the way. Glad to hear that it is unneccessary. I'll get a couple of bushings and torque it down. Glad to hear that it will work just fine.
glenerd51
2004 - 2008 F150
Jun 26, 2013 10:06 PM
Aussie_F_trucker
Feb 3, 2013 02:52 PM
f1501987
Apr 28, 2012 06:05 AM
schlager
May 15, 2006 10:37 PM
buzzard
Aug 20, 2001 01:25 AM
