Quick Question
Old Aug 14, 2001 | 04:01 PM
buzzard's Avatar
buzzard
Quick Question
Old Aug 18, 2001 | 04:21 PM
daf_62's Avatar
daf_62
Quick Question
'69 F250 390
Fuel Filter... before the mechanical fuel pump or after or both?
I've heard after is best, but someone said that if you don't put one before the mechanical pump, it could run dry and burn up.
Thanks
Doug
Old Aug 18, 2001 | 04:39 PM
Ratsmoker's Avatar
Ratsmoker
Quick Question
Mine is right before the carb. This in my opinion would be the best location. If by some crazy chance your fuel pump starts shaving metal this would stop it from trashing your carb. One before and after the pump wouldn't even be a bad idea as long as you get enough fuel. For a stock engine this shouldn't be a problem.
Old Aug 19, 2001 | 07:45 PM
390fe's Avatar
390fe
Quick Question
My '70 has a filter has a filter at the pump and again at the carb. My '78 has three filters. One before the pump, one at the pump, and one at the carb.
Jason Kendrick
1970 F100 Custom 390/C6
1978 F150 Ranger Lariat Supercab 460/C6
Old Aug 19, 2001 | 08:06 PM
FE427TP's Avatar
FE427TP
Quick Question
I thought stock FE's had the fuel filter built into the pump?
Old Aug 19, 2001 | 08:20 PM
bsprowl's Avatar
bsprowl
Quick Question
On trucks that may be true, but its not true for all FEs.
Bob
'66 7 Litre, top loader, 3.25 Traction-lock, Sidewinder Intake, SCJ Exhaust
'88 F150 LWB 4x2, XLT Lariat, 302, 5 speed, 3.08
'99 Ranger, 4x2, 3.0, 5 speed, 3.73 posi
Old Aug 20, 2001 | 01:25 AM
karljay's Avatar
karljay
Quick Question
[font size="1" color="#FF0000"]LAST EDITED ON 20-Aug-01 AT 02:27 AM (EST)[/font][p]I got a Carter special ordered from Kragen that had the filter built in to the bottom of the pump.
I think it's best to have one before the pump to keep stuff from damaging the pump. I think the pump itself is just a rubber diaphram and might be dammaged by stuff from the tank.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
