'04 Diesel F250 4wd (not a dually). Am I correct that it has a Dana 60 in front and a Sterling 10.25 in the rear? I'm looking at some replacement diff covers that have drain plugs.
I guess I'm looking for a set that are less pricey than the Mag's... but would really like to have a drain plug. Looks like the '08 OEM version is plug-less.
You have the Sterling 10.5 out back but many of the 10.25 parts will work on it.
Pulling the cover off to drain the fluid does a better job than using a drain plug. There are little sump like pockets at the bottom of the diff housing that should be cleaned out and you can't do that with the cover on.
