P0102
Old Nov 3, 2005 | 11:32 PM
tumark's Avatar
tumark
Red face P0102
Well, I installed a 2.5L from a 2001 ranger into my 1998. (first time doing an engine replacement!) Started up right away but soon dies, can only keep it running by giving it gas, the check engine light is on and the only code retreived was P0102, I unplugged and reconnected the wires to the MAF sensor, no luck. Hard to believe the sensor went bad while I was cussing out nuts and bolts during an engine install!
Any suggestions on what I could do to find and correct this problem?
PS I did install new spark plugs & wires, I tried another used ignition coil pack but no difference.
Any suggestions would be appreciated!
Mark
Old Nov 3, 2005 | 11:52 PM
Rockledge's Avatar
Rockledge
Any way you can grab the MAF from the donor vehicle?
Are you getting 12V at the MAF's red wire?
One of the PCM "tests" of the MAF involves comparing it's signal with that of the TPS. Hence, make sure your TPS and it's circuit are OK, too.
Old Nov 4, 2005 | 09:04 AM
tumark's Avatar
tumark
thanks
no I already checked about getting the sensor from the doner ranger. interesting about the tps sensor I will check it out when I clean the maf sensor. I read another ranger user used electronic spray cleaner to clean it. Then again another dude had to replace the sensor to correct his problem.
Not sure if checking volatage at the red wire is valid with the engine in the on position only, wont idle for me long enough to check voltage
thanks again for the suggestions
Mark
Old Nov 4, 2005 | 09:56 AM
Rockledge's Avatar
Rockledge
If the key is on, you should get 12V at the red wire. It doesn't matter if the engine is running or not. The red wire is common power for things such as the MAF, the fuel injectors, the IAC, etc.
Old Nov 4, 2005 | 11:04 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Beware of electrical contact cleaners that contain lubricant. Brake cleaner works well.
Old Nov 4, 2005 | 12:54 PM
tumark's Avatar
tumark
thanks!!
I picked up some electrical contact cleaner from Kragen, said it leaves no residual. It did the trick!!! engine runs smooth, cleared dtc and did not reoccur. Now on to checking engine cooling before doing a road test.
Thanks again for your time and suggestions
Mark
chadaaron
New Member Introductions
Dec 30, 2015 02:47 AM
solar2012
Mar 21, 2015 10:14 AM
LeoH
May 29, 2014 12:09 PM
khadma
1997 - 2003 F150
Sep 24, 2011 11:01 PM
