When to replace brake pads?
Old Nov 3, 2005 | 06:08 PM
orleec's Avatar
orleec
re: 99 XLT 4x4
When I changed my tires for upcoming winter, I checked on my brake pads (okay my method was not very scientific so pls bear with me) and I have the fronts pads about as thick as the metal backing, whereas the rears are a lot thicker.
In my previous 94 Galant, I had the front pads used-up almost to the metal and the caliper piston rubber boot held, no problem.
In my wife's 98 V70, the rubber boot broke away from the caliper, when front pads were about as thick as the metal backing, the rotors being still within spec. Eventually, the pistons rusted, and I had a frozen break.
Thus my question, am I still good for the winter? (getting cold to work on vehicles)
Thanks
Old Nov 3, 2005 | 06:57 PM
holiday187's Avatar
holiday187
don't forget to turn your rotors or you'll die.
Old Nov 3, 2005 | 07:24 PM
MisterCMK's Avatar
MisterCMK
Don't even start that again buddy.
OP - You should be fine, thats a lot of meat left on the pad.
Old Nov 3, 2005 | 07:48 PM
holiday187's Avatar
holiday187
start what?? LOL
i'm jsut saying he needs to turn the rotors or he'll die.
Old Nov 4, 2005 | 12:59 AM
MisterCMK's Avatar
MisterCMK
You know exactly what I'm talkin about
Old Nov 4, 2005 | 01:48 AM
Monsta's Avatar
Monsta
Sit. Stay.
Humor: (or HumoUr if you're Canadian)...I like that. Just don't let it get out of hand like before holiday'.
Old Nov 4, 2005 | 07:10 AM
orleec's Avatar
orleec
Thanks, the braking of the vehicle is fine btw, so I guess I'll work/check on it next spring when I change the tires with my summer set.
CBB9M
1983 - 2012 Ranger & B-Series
19
Dec 9, 2014 01:50 AM
sean23johnson
22
Apr 12, 2013 04:09 PM
IDIDieselJohn
May 27, 2011 04:38 PM
ford390gashog
Feb 20, 2005 10:32 PM
Shedstomper
1997 - 2003 F150
Aug 7, 2003 09:09 AM
