I'm swaping cabs on my 79' f150 300 I6 4spd 4x4, How do i remove the shifter out of the 4 speed, i believe its a np435 someone said i have to push down on it and twist is this true? and also how do i remove the t case shifter also it would make it alot easier to swap the cabs, thanks
Yes just push down and twist on the metal cover on the ball on the shifter. Some have been known to wear to the point where shifter will come out and you are left holding it in your hand.
I used to hate this part of tranny r&r,until a friend showed me a trick.Just grab a roll of black electrician's tape,take off the shifter **** and drop the roll of tape down over the tranny tower.Push down on the outside of the roll and turn-it'll pop right out.You won't believe how good this works.
