Mechanical diode question
Old Nov 2, 2005 | 02:00 AM
ladiabla74's Avatar
ladiabla74
Does anyone know in detail what the function of the mechanical diode is in the auto tranny? I called bauman engineering to get a parts list of what I would need to beefup a 92 AOD tranny for my 74 truck to couple to a 351C and he mentioned that but did not get the chance to ask him what that was for.
AC
Old Nov 2, 2005 | 07:20 AM
Casey's Avatar
Casey
The mechanical diode is a one way clutch. It holds torque in one direction and overruns in the other direction. As to why the trans needs this, it would take pages to explain.
A one way clutch is also used on a bicycle. That's how you can pedal the bike forward, but the pedals just rotate backwards, or the bike can coast while you are not pedalling.
Old Nov 2, 2005 | 08:55 PM
ladiabla74's Avatar
ladiabla74
What is the big advantage of installing it on the AOD retrofit? Does the 80 to 93 AOD not have it? Is there a site you can recomend to learn about it? Thanks for the input.
AC
Old Nov 3, 2005 | 07:13 AM
Casey's Avatar
Casey
The mechanical diode is stronger than the older one way clutch. Here is probalby a lot more than you want to know about it:
http://www.epilogics.com/md/tekintro.htm
moejr
Electrical Systems/Wiring
Dec 5, 2016 09:58 AM
mrbison
Dec 25, 2015 07:02 PM
74baja
31
Oct 14, 2009 08:26 AM
Trouble1263
Apr 26, 2009 02:53 PM
Storogoth
Colorado Chapter
Dec 30, 2007 05:26 PM
