EGR 06 PSD (engine light)
Old Nov 2, 2005 | 07:40 PM
  #31
kw5413's Avatar
kw5413
Yes usroute66 you are correct.
BTW: I have never liked calling it a dummy valve. I have used faux valve as it seemed more descriptive but, I also felt it seemed a bit elitist as well.
As it turns out, I guess dummy (an imitation, copy, or likeness of something used as a substitute) is still the best terminology.
Customz, it seems that since we have the answer to the original post you are going to have to get creative to rid yourself of the dreaded WART syndrome.
Old Nov 2, 2005 | 07:49 PM
  #32
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
The dummy valve will work ONLY on an 05 without mass air. On anything else, its worthless.
On an 03/04, you don't need it if you aren't california emissions because the codes won't throw a CEL. If you have an 06, you are just plain screwed unless you want to go to more trouble.
Old Nov 2, 2005 | 07:52 PM
  #33
kw5413's Avatar
kw5413
And just think...for '07 we get a multiple EGR Valve strategy....whooooopeeeee
Old Nov 2, 2005 | 07:55 PM
  #34
SpartanDieselTech
Former Vendor
Calm down, it is only a single valve with multiple ports.
And besides, for every one they put on...we can figure out a way to maim, rape, and remove it
Old Nov 2, 2005 | 08:15 PM
  #35
kw5413's Avatar
kw5413
So what doses this mean? From one of the International big shot VP interviews:
The new 6.4L Powerstroke will have dual EGR systems with separate coolers
Same thing you said? Just different?
Old Nov 2, 2005 | 08:16 PM
  #36
SpartanDieselTech
Former Vendor
No, not exactly....
Hmmm... I'll have to find out more on this one.
Old Nov 2, 2005 | 08:19 PM
  #37
kw5413's Avatar
kw5413
Go here for the interview.
http://www.dieselforecast.com/Displa...p?newsroomID=7
Old Jan 6, 2006 | 02:11 PM
  #38
Tdusseau's Avatar
Tdusseau
EGR Bypass
Has anyone thought about just jumping the wires on the plug instead of buying another EGR? Is this even possible? Just not into spending the cash for a new one I am not going to use. I also suffer from the 4-8lbs of boost loss with it disconnected.
barthel
Nov 12, 2014 08:25 PM
jas67
Sep 30, 2009 07:42 PM
mylesdixon
Feb 18, 2009 10:06 AM
jasonwf350
Jul 10, 2006 06:07 AM
slowmans
Mar 18, 2006 07:29 PM
