Instrument Cluster issues
Old Oct 30, 2005 | 11:41 PM
desperado_18_2000's Avatar
desperado_18_2000
I recently swapped in a instrument cluster with tach, to my 83 F-150. When it was first installed the gauges worked correctly, minus the tach. Now after having it in a short while, all my gauges have stopped working aside from the voltage meter. What could have gone wrong here? Fuse maybe?
Maybe i could take the instrument cluster printed circuit board and swap it to my old cluster and install the tach in it? Would this work?
I've yet to test the tach outside the cluster...i'm not worried about that. I just want my gauges back.
Old Oct 31, 2005 | 12:59 PM
Piffery1's Avatar
Piffery1
Could be: 1. Instrument voltage regulator bad. 2. Instrument Cluster Ground bad, resistance from instrument voltage ground terminal to chassis ground should be 1 Ohm or less (or run a seperate ground wire from instrument voltage regulator mounting tab screw to chassis ground) . 3. Bad resistance wire (black/light green) in wiring harness (supplies voltage from Ignition Switch "Run" to instrument voltage regulator) or "open" somewhere in this circuit. To check: disconnect battery and measure resistance from instrument voltage regulator input terminal to + battery terminal with ignition switch in "Run" using an Ohmmeter. Resistance should be 8 to 9 Ohms or so. 4. Poor connection at instrument cluster plug or break in printed wiring assembly.
Nathan Plemons
Jun 14, 2013 01:56 PM
4EyedTurd
Oct 12, 2012 03:22 AM
thunderbirdcakes
Aug 7, 2012 03:05 PM
Anafiel
47
Nov 26, 2010 11:19 AM
del1650
Mar 17, 2006 12:24 AM
