key pad entry 00' EXP-EB
Old Oct 30, 2005 | 05:52 PM
russ1416807's Avatar
russ1416807
Where Can I Find The Code 4 The Key Pad 2 Unlock The Doors?
Thanks Guys!
Old Oct 30, 2005 | 06:04 PM
EagleDakota's Avatar
EagleDakota
The factory set 5 digit code is found on the owner's wallet card or taped onto the computer module. I am not sure where this module is located. If this code does not work then the factory set code has been changed. That may give you a lot of grief. Hopefully the factory code is still valid.
Old Oct 30, 2005 | 07:00 PM
PaulC's Avatar
PaulC
The factory code is always valid. It cannot be changed unless you spend some cash to replace an electronic module. Look deep under the dash on the driver's side, near the parking brake for a white plastic box with a white paper sticker. The sticker will display the five digit number that you are looking for.
Old Oct 30, 2005 | 10:46 PM
russ1416807
Thank U Paul
Old Oct 31, 2005 | 08:02 AM
TROPHYMAN's Avatar
TROPHYMAN
I found mine while installing a remote starting system on my 00 Expy. Sure is nice having it.
Old Oct 31, 2005 | 09:29 AM
EagleDakota
What a great forum! Russ1416807 asks a good question and we all benefit! Thanks everyone.
bkuuz1
6.7L Power Stroke Diesel
Sep 27, 2016 09:37 PM
racin
1997 - 2003 F150
Mar 13, 2016 08:59 PM
jims406rs
Escape & Escape Hybrid
23
Dec 5, 2015 05:00 PM
broncobilly66
2004 - 2008 F150
13
Oct 14, 2008 10:16 PM
mdutra
Jul 18, 2007 06:20 PM
