Offroad & 4x4
Wristed radius arm.
Old Nov 8, 2005 | 12:46 AM
kopfenjager's Avatar
kopfenjager
This is a definite mod I want to do. Looks fairley strait forward.
Old Nov 23, 2005 | 01:22 AM
Oval_obsessed's Avatar
Oval_obsessed
Well, I starting on this tomorrow. I have most of the steel cut, 1/2 in flat stock, all I need is to finish cleaning the surface and to weld. Does anyone have any advice for me on anything?
One more question, when the truck is on level ground, will the pin hole line up most of the time or is it going to be a pain trying to put the pin back in?
Old Nov 23, 2005 | 02:32 AM
DJEkim33's Avatar
DJEkim33
Never heard of this set up before. I was wodering if you use an extended radius arm with this set up. I just installed extended radius arms on my truck and love the extra flex they provide. Do you end up with excessive front wheel hop with this set up and or axle wrap. Also just an observation about the Exploder pictures but it appears to just have a grade 5 bolt in there. Wouldn't this be alittle unsfe on the free way?
Old Nov 23, 2005 | 10:14 AM
Oval_obsessed
I'm just usig a factory arm from a '77. I found a couple of examples of them on a Google search. Everyone has been saying that as long as you have the pin in, it should be the same as a regular radius arm.
Old Nov 23, 2005 | 11:35 AM
homenf's Avatar
homenf
http://www.lonestar-ebc.com/Tech/TechItem.asp?TechId=13.
This seems to be a good way to follow.
Old Nov 23, 2005 | 05:40 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
normally there is no trouble lining the pin up
Old Dec 3, 2005 | 01:15 AM
Oval_obsessed
I finished my radius arm up tonight besides painting it. Check out my gallery and see what you think.
z31freakify
Nov 17, 2016 08:15 AM
Romel77
23
Feb 11, 2016 06:13 AM
94iditpuller
20
Dec 9, 2015 08:42 PM
85bobtail
Mar 30, 2012 07:48 AM
fatdaddy
Jun 29, 2002 08:14 PM
