Taller Tires?
Old Oct 29, 2005 | 07:21 AM
Wayne88's Avatar
Wayne88
Taller Tires?
Hi everyone, This looks like an awesome forums site. This is my first post, and I've got a question that might be a little dumb. I bought my 05 X last night and think the tires are a little small for the vehicle. It is an XLT 4X4. Can I put taller tires on the stock rims without lifting the vehicle and making it look like I jammed the tires into the wheel well, or do I have to lift it?
Old Oct 29, 2005 | 07:30 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 29, 2005 | 09:43 AM
rozett's Avatar
rozett
Wayne, Welcome!!
I've put 285 Bridgestone Dueler AT REVOs on mine. They are a great tire and the bigger size fills in the wheel well much better. But some guys have gone to even bigger tires. Here in Maine, we can not increase tire size more than two notches if you ABS brakes, and no lifts either.
Old Oct 29, 2005 | 10:51 AM
cficare's Avatar
cficare
I installed 305-70R-16 Load Range "E" tires with no lift, but it required changing the rims to 16x8.
Old Oct 29, 2005 | 11:42 AM
1buzzbait's Avatar
1buzzbait
Originally Posted by rozett
Wayne, Welcome!!
ditto here w/the revo's no mods needed,didnt affect abs,speedo etc.
Old Oct 29, 2005 | 02:03 PM
Rev Den's Avatar
Rev Den
285/75-16D BFG A/T Stock rims, no sweat. Even though they are D rated they are rated the to the same rate as many of the E rated tires, plus...they are BFG's.
JMHO
Rev
Old Oct 29, 2005 | 02:10 PM
1buzzbait's Avatar
1buzzbait
if ya hafta have bfg's i saw that they offer a 285 in e- rate, trouble is findin them, i still would walk over a set for revo's though!!
Old Oct 29, 2005 | 05:33 PM
Wayne88's Avatar
Wayne88
Thanks
Thanks for the replies. It currently has the stock BFG 265/75R 16 tires. Approximately how much taller is the Revo tire?
Old Oct 29, 2005 | 07:10 PM
tfalk's Avatar
tfalk
I installed V springs in the front which picked it up 1.75". With 295-75-16's on 16x8
rims, I get a slight rub at full turn - the edge of the tires are hitting the fender liners.
glenerd51
2004 - 2008 F150
May 7, 2013 11:03 AM
Ace!
Jan 1, 2011 12:40 PM
kjd2121
1978 - 1996 Big Bronco
21
Jul 21, 2006 08:35 AM
Dirtyboy
Mar 23, 2003 05:58 PM
rebelbob
Oct 23, 2002 03:51 PM
