electronic brake control
Old Oct 28, 2005 | 12:00 PM
cool guy's Avatar
cool guy
i am having trouble connecting the electronic brake control wirings, i foung the connector but i don't know where to connect thos 5 wires, need help
Old Oct 28, 2005 | 01:38 PM
99Xplr's Avatar
99Xplr
What controller do you have? I just installed a Tekonsha Prodigy and it only took me 15 minutes to wire up and mount. Lemme know a little more detail on what you question is and I'll help you hook it up right.
Old Oct 28, 2005 | 03:38 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 28, 2005 | 06:27 PM
keith Ruge's Avatar
keith Ruge
I also did the same ,If you got a Tekonsha Prodigy GO too there web site and itle give you the color code >
Old Oct 29, 2005 | 01:18 AM
cool guy's Avatar
cool guy
i'm not really sure, how can i tell?......pls respond..
Old Oct 29, 2005 | 01:24 AM
cool guy's Avatar
cool guy
also it came with the truck.....i'm not really sure if i need to splice it somewhere?
Old Oct 29, 2005 | 01:54 AM
aldridgec's Avatar
aldridgec
The wire harness that you are talking about is for use with an aftermarket brake controller that you have to buy, mount and then wire to the truck. The wires connect to the brake controller, then plug in under the dash. Makes it easy to mount, and even move between vehicles.
Old Oct 29, 2005 | 07:01 PM
VBigFord20's Avatar
VBigFord20
Don't forget to put the relay in otherwise its useless.
I don't know how you mounted yours but I did mine like this:
Old Oct 30, 2005 | 01:44 PM
cool guy's Avatar
cool guy
thanks guys!!!
Old Nov 9, 2005 | 02:16 PM
gregghealy's Avatar
gregghealy
My controller came out of an Explorer, plugged right in. Put the relay that came with the tow package in, but according to the manual I am still missing a few fuses...
Is this possible, or should I have full trailer functionality (brake controller, trailer lights, charging) with only installing the relay that came in the tow package bag?
The brake controller gives me a red dot when I hit the brakes. Does this mean its working, or not working? Have to go pick the trailer up tomorrow, I hate to find out for sure (that it isnt) while Im towing the trailer back to the house...
Old Nov 9, 2005 | 03:39 PM
kd4crs's Avatar
kd4crs
If your controller is like mine the red dot means it is working. Once you have a trailer hooked to it the display should show the amount of braking power going to the trailer.
Old Nov 9, 2005 | 04:36 PM
gregghealy's Avatar
gregghealy
Good deal... The only wother thing Im concerned about because of the fuses is battery charging and lights. I guess Ill have to find out and add fuses as needed...
Thanks!
Old Nov 9, 2005 | 05:12 PM
kd4crs's Avatar
kd4crs
greg,
The relay energizes the battery charging circuit when your ignition is on and the fuses power the charging, lights, and brakes on the trailer. Be sure to put in the correct rated fuses and you should be fine.
