Cleaning inside the cowl.
Old Oct 28, 2005 | 10:38 AM
bigsnow's Avatar
bigsnow
Is there a good way to get all those fir needles and maple tree seeds out of the cowl vents? It's a 78 f-250. Thanks
Old Oct 28, 2005 | 11:22 AM
highboy1975's Avatar
highboy1975
there is no really good way, the cowl goes over to the vent boxes on the side of the cab. theres drain holes on the boxes. i just ran water through it and let everything run out the bottoms of the boxes. might not work for something as large as fir needles and such. theres a plug in the front of the box, but that could be a pain to get to.
Old Oct 28, 2005 | 01:11 PM
Mil1ion's Avatar
Mil1ion
Actually if everything is dry there is another way.
Set up an air compressor system and put an air blower attachment on the hose.
Blow out one end of the cowl to get it clean, now take a stiff piece of cardboard (folded to fit the slot but will open wider to fill the width of the cowl)
now, shove it through the last grill slot (on the end that you cleaned) and lay it in at a 45* angle right to the bottom of the cowl.
Now blow out the crap starting at the end that wasn't clean.
This should remove close to 99% of the debris unless there are wet leaves in there.
If the leaves are dry, crush them to little pieces.
Old Oct 28, 2005 | 01:54 PM
dakonthemountain's Avatar
dakonthemountain
Dennis,
Thanks for that tip! I have often been frustrated with the pine needles that get in my cowl also, as I live in the mountains..
Dak
Old Apr 28, 2006 | 01:53 PM
C. Lee Colbert's Avatar
C. Lee Colbert
Is there any way to keep more needles and seeds from falling in and accumulating?
Old Apr 29, 2006 | 10:47 AM
Mil1ion's Avatar
Mil1ion
Don't park under tress
Aside from installing a cowl cover, no.
Old Apr 29, 2006 | 09:28 PM
broke77f100's Avatar
broke77f100
well u could "shave" the cowl using body filler? i am going to with my truck
Old Apr 30, 2006 | 12:01 AM
Mil1ion's Avatar
Mil1ion
Where will you get fresh air for the heater system then ?
Old Apr 30, 2006 | 12:08 AM
fozzy's Avatar
fozzy
I removed my front fender splashshields today to get ready for painting, and I noticed the "chute" or vent where that stuff is supposed to fall out from the upper cowl. Its under your front splash shields if you have a clog. I noticed old beehives and stuff that helped start a jam.
Old Apr 30, 2006 | 12:18 AM
Bdox's Avatar
Bdox
Since I have about 25 Doug Firs on my lot, I put 1/8 mesh screen under the cowl grill. It's about 95% effective.
Old Apr 30, 2006 | 12:27 AM
fozzy's Avatar
fozzy
That is a great idea!! How did you get it in there without looking badly?
Old Apr 30, 2006 | 12:45 AM
Bdox's Avatar
Bdox
pulled the grill, carefully cut and bent the mesh to fit. Attached it with hot glue to avoid fasteners. Once it's in place, it is trapped.
Old Apr 30, 2006 | 10:47 AM
broke77f100
Mil1on who needs the heater? lol im not driving my truck in the winter
Old Apr 30, 2006 | 11:05 AM
460f250's Avatar
460f250
When removing my old doors I ended up breaking most of the bolts because they were rusted/seized inside the cab frame. I had to cut open the inside kick panel to get at the plate they bolt into and when I saw the mud and junk in there it was no wonder everything was rusty. Nice and clean inside now, just have to weld the access back up now.
Old Apr 30, 2006 | 12:21 PM
Mil1ion's Avatar
Mil1ion
Bdox, You pulled the grill ?
The cowl with the fresh air grill is one piece construction and the grill doesn't come out.
What do you mean ....you pulled it ?
