question on Auto trany cooling
Old Oct 31, 2005 | 08:24 AM
Casey's Avatar
Casey
I'm saying that it's stupid to remove the radiator cooler if you are in a warmer climate. They say to leave the cooler in place in a cold climate.
Why do you need the extra cooling when it's cold? You need it when it's hot.
The real problem is that TCI (and many others, too) seem to think that the radiator is there to heat the trans fluid. IT DOES NOT HEAT THE TRANS FLUID IN THE WINTER!!!!!!!!!!!!!!!!!!!!! It cools the trans fluid, in the summer and especially in the winter.
If you don't believe me next time it's really cold get you truck well warmed up and check out how how the cold side of the radiator is. That's the side where the trans cooler is located. You will find that it is nearly the same temperature as the outside air.
Old Oct 31, 2005 | 09:41 AM
seventyseven250's Avatar
seventyseven250
I'm with you Casey, I don't see how the raditator can heat the tranny fluid when it's not being used (thermostat is closed, not hot fluid flow).
Old Oct 31, 2005 | 10:11 AM
Casey's Avatar
Casey
Finally! Someone that understands!
Old Oct 31, 2005 | 02:17 PM
seventyseven250
well, I normally try not to disagree with Ivan, at least not when he can hear me, but on this one, I think I've got no choice.
Old Oct 31, 2005 | 02:36 PM
ivanribic's Avatar
ivanribic
I got what you're saying Casey. I've never put my hand on the bottom of a radiator when it's warm because I know how hot the top is. On my aluminum rad the cooler is on the side and I know if I touch that while I'm at operating temp it'll fry my hand but it's a different setup than the stock unit.
77, feel free to diagree with me any time I'm wrong.
Old Oct 31, 2005 | 02:58 PM
monsterbaby's Avatar
monsterbaby
Oh I was gonna make a comment but think I will just say never mind in this case, and let it slide.
Old Oct 31, 2005 | 04:05 PM
ivanribic's Avatar
ivanribic
No 35's to burn out for you Rob!
F350-6
6.7L Power Stroke Diesel
Dec 5, 2016 07:12 PM
tolvibman
Aerostar
61
May 6, 2013 06:55 AM
BSilk
Mar 3, 2009 02:58 PM
bigdogger
Jan 27, 2005 03:24 AM
JoeN
1978 - 1996 Big Bronco
Jun 12, 2001 03:01 PM
