Sponsored by: Innova
random question
Old Oct 27, 2005 | 09:07 PM
lilbob1131's Avatar
lilbob1131
random question
what exactly would happen if instead of connecting positive and negative i did pos. and pos or neg and neg.? dont think im an idiot and went off and did this i am just wondering/
Old Oct 27, 2005 | 09:28 PM
sardog's Avatar
sardog
what exactly are you asking, swapping leads. puting positive where neg. should go and the other way around? if that is the case you are swapping polarity and sending the current the wrong direction. dependent on what kind of equipment you are using it can mess up but as far as speakers go it doesnt make that much of a difference.
Old Oct 27, 2005 | 09:32 PM
lilbob1131's Avatar
lilbob1131
im talking bout like from my amp i hooked my subs up to the two positive slots
Old Oct 27, 2005 | 09:34 PM
sardog's Avatar
sardog
nothing will happen. they are on 2 seperate circuits and it wont do anything at all.
Old Oct 28, 2005 | 02:22 AM
RomerB2's Avatar
RomerB2
Nothing will happen, no noise at all. But I wouldn't reverse polarity on them.
Old Oct 30, 2005 | 11:28 AM
RangerPilot's Avatar
RangerPilot
When you reverse the polarity of speakers it makes them fire in reverse which can (eventually) damage them according to some manufactureres. Not reccommended, but I did it for three weeks in my Ranger on accident before I fixed it and never noticed any difference, just as loud and clear as all the other speakers. *shrug*
Old Oct 30, 2005 | 01:11 PM
LinearPower's Avatar
LinearPower
Connecting speakers to an amp with the polarity opposite of what it should be causes the speaker cone to be moving in the opposite direction of how it should be. And it does affect how the speaker sounds, especially the bass response. A quick way to check is to use a 9V battery and on the amplifier end of the wire, touch the ends of the wire to the battery terminals. When the cone moves outward is when the + speaker wire is on the positive terminal of the battery. Only do this for a split second, and DO NOT do this on tweeters.
Old Oct 30, 2005 | 11:31 PM
lilbob1131's Avatar
lilbob1131
ok i did something rong here. i just bearly bought me one of those crossovers for stock radios so u can plug amps into the stock unit. i hooked it all up and pluged in some old speakers to check to see if it was goin to work and teh speakers make a static sound at low levels. coudl someone help me?
Old Oct 31, 2005 | 10:48 AM
fordboy_52's Avatar
fordboy_52
some speakers work better in reverse. Most hate it though.
Matt
Old Oct 31, 2005 | 11:27 AM
RomerB2's Avatar
RomerB2
Why would they work better with reverse polarity? If this were true then the manufacturer would stamp + and - reversed then.
Old Oct 31, 2005 | 04:47 PM
RangerPilot
Yeah really. I don't know of any speakers that fire better in reverse. Subs definetly wouldn't. Tweeters wouldn't. And I highly doubt the midranges do since they sound worse... so yeah. Your evidence being?
Old Oct 31, 2005 | 07:45 PM
lilbob1131's Avatar
lilbob1131
allright, i hooked some "test speakers" up to my friends radio and everyhitng is workin good. i hook them up to mine and everything is not good. i am getting a static noise out of them
Monsterford22
Sep 14, 2016 07:47 PM
mark's1984
Apr 19, 2016 07:04 AM
Dr D
Electrical Systems/Wiring
Jun 30, 2015 05:50 AM
new mexico 53f600
May 21, 2014 11:22 AM
Brian1950F4
Feb 24, 2014 01:08 PM
