Sponsored by: Kumho
torque spec on u-bolts
Old Oct 27, 2005 | 08:41 PM
fordmancounty's Avatar
fordmancounty
Question torque spec on u-bolts
i was wondering if somebody could tell me where
i can get the torque spec's for the you bolts after
replacing the leafs.
Old Oct 27, 2005 | 10:47 PM
someday's Avatar
someday
what kind of truck do you have?...regardless, the torque wrench you most probably have goes up to 150 ftlbs and would start there
Old Oct 28, 2005 | 01:53 PM
seventyseven250's Avatar
seventyseven250
I'm not sure of the spec, but it's pretty high to be sure. I'd guess somewhere between 100 and 200 would be fine. Don't go all crazy with the snipe, that's a waste of effort.
Old Oct 28, 2005 | 08:37 PM
fordmancounty
i have an 87 for f-150 4x4. and i have a torque wrench
that goes 250lbs. thanks guys.
Old Oct 28, 2005 | 09:23 PM
someday's Avatar
someday
according to my haynes manuel f100,150,250,lightning,bronco 75-100 ftlbs...over 8500 gvw 250/350 150-210ftlbs
Old Oct 29, 2005 | 10:51 PM
someday's Avatar
someday
i forgot to mention it is recommended to replace the ubolts when serviced
Old Oct 30, 2005 | 08:19 AM
fordmancounty
Thank You. For The Info.
Old Nov 6, 2005 | 07:07 PM
fordmancounty
[B]hey got the springs replaced man does the truck ever ride better than
it did. i torqued the bolts to 110lbs. my haynes book said 75 to 115. so thank
to all for the info
.[/B]
Old Nov 22, 2005 | 01:46 PM
7fords's Avatar
7fords
when torquing new u bolts you should lightly coat them with oil and torque them 75-90 foot pounds of torque torquing dry wont give you a true reading. also after you have driven a couple hundred miles retorque them there is such athing as to much torque
cadunkle
Nov 19, 2016 06:59 PM
Deluxe06
Nov 7, 2016 05:09 AM
green_95
Jun 17, 2016 12:37 PM
tigerfan79
Mar 6, 2016 09:54 PM
drunkdave
1978 - 1996 Big Bronco
Nov 2, 2008 05:56 PM
