Ford says B5 is the limit; how much B20?
Old 10-30-2005, 10:10 PM
tdc3's Avatar
tdc3
tdc3 is offline
I'm trying to figure out how much B20 (only mix avail in my area) I can put in a 29 gal tank and not blow Ford's B5 limit. Are these calc's correct?
Assumptions:
  • B20 = 20% BD / 80% Petro (0.25)
  • B5 = 5% BD / 95% Petro (0.05)
  • 29 gal total
Calculations:
  1. 0.25X = 0.05
  2. X = 0.05/0.25 = 0.20
  3. 29(0.20) = 5.8 gal of B20
So, I could put 5.8 gal of B20 + 23.2 gal of pure petro diesel into an empty 29 gal tank and be within Ford's limit, right?
Thanks...
Old 10-31-2005, 12:17 AM
rray32539's Avatar
rray32539
rray32539 is offline
I was never a whiz at algebra, but your figures look correct to me.
Old 10-31-2005, 03:02 AM
4wd's Avatar
4wd
4wd is offline
First break down what the factory recommendation is:
5% of 29 gallons= 1.45 gal of pure 100%bio diesel allowed with each 27.55 gallons of pure 100% diesel.
So, @20% bio diesel, 1.45/.2 = 7.25 gallons of 20% would get you the max (1.45 gal) of bio and 5.8 of pure 100% diesel. Now, add another 21.75 gal of pure 100% diesel (27.55-5.8) and you should be at the recommended mixture rate.
Old 11-01-2005, 07:55 PM
tdc3's Avatar
tdc3
tdc3 is offline
Makes sense...
Thanks much. Either way, pity it's such a small amount of BD allowed!
Old 11-02-2005, 10:58 PM
kennedyford's Avatar
kennedyford
kennedyford is offline
What ford says in this matter is irrelevant. Your truck can run any mixture due to its inheirent properties. Exponential lubrication abilities, high oxegen content, extremly reduced soot emissions, and the natural cleaning atributes, higher cetane rating and finally horsepower increase as well as milage. Do some research and run whatever you want. B100 is clear and cleaner.
Old 11-04-2005, 07:36 AM
tdc3's Avatar
tdc3
tdc3 is offline
I hear ya, but if Ford won't warranty a $5K+ engine option because I ran over their recommended limit that seems pretty risky if within the warranty period. After the warranty period, your opinion makes perfect sense!
Old 11-04-2005, 10:06 AM
kennedyford
Oh yeah you want to protect yourself from those ford **** mechanics. You dont want them making up stuff like they did on our truck. This one guy says he made no mistakes and the whole shop backed him....anyway If you mix yourself up 20 you will be able to feel the positives and they would not be able to tell unless they sent the fuel in for analysis. I doubt they would do that. You could even run b100 for say 1/4 to 1/2 tanks at a time, and fill up with dino alternating. Anyway have just plain fun.
Old 11-10-2005, 07:37 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
PowerstrokeJunkie is offline
i am going to get some bio-d on my next fill up. so youre saying the b-100 is clear, like water? that is cool!
Old 11-13-2005, 11:10 PM
kennedyford
Clear, super duper clean of the products I have seen. Im topping off tomarrow at a local place with b100.
Tomahawk
135
05-28-2016 05:39 PM
2009kr
2017+ Super Duty
05-14-2016 03:52 PM
Redrkt
1999 to 2016 Super Duty
09-20-2014 03:48 PM
51PanelMan
13
03-04-2014 11:46 PM
Quick Reply: Ford says B5 is the limit; how much B20?
