Heating and AC malfunctions
Old Oct 26, 2005 | 09:06 AM
Mythreefords's Avatar
Mythreefords
Hello,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p>
I'm having trouble with my ac and heating on my 96 F150, in the summertime when I switch from panel to max ac it will blow out the dash ducts for a while then switch to the defrost ducts, it doesn't do this all the time, what I’ve noticed is when the vehicle is sitting still idling in the driveway it seems to work fine for as long as you sit there, I can drive it less then 5 miles and it will change to the defrost duct.<o:p></o:p>
Then here comes fall, when I start up and switch to the defrost mode and let her warm up, sometimes I get hot air and then bam cold air comes out the defroster.<o:p></o:p>
<o:p></o:p>
Any suggestions.<o:p></o:p>
Thanks,<o:p></o:p>
Randy<o:p></o:p>
Old Oct 26, 2005 | 12:12 PM
gibsonj's Avatar
gibsonj
This sounds like a blend door problem to me. The blend door opens and closes to redirect air between the floor/dash vents and the defrost vents.
My old 92 F150 had this problem, and turned out to be a broke vacuum line (little white straw under the hood back near the heater core). When I touched it, it disintegrated in my hands---those little plastic lines are notorious for dry rot.
I just cut out the brittle section, and fitted the two ends into a traditional rubber vacuum hose with ID equivalent to the OD of the plastic line. Works like a champ.
Old Oct 26, 2005 | 01:05 PM
Mythreefords
Thanks gibsonj,
I’ll give this a try and let you know.
Randy
Old Oct 26, 2005 | 05:21 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Randy, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Snowlover
Oct 28, 2014 07:11 AM
RV-Dean
Feb 26, 2008 04:38 PM
Residence
New Member Introductions
Nov 6, 2007 08:15 PM
jd111404
Apr 21, 2007 12:25 PM
kl67
Feb 14, 2007 05:14 AM
