EBPV operation
Old Oct 25, 2005 | 08:11 AM
RAMPAGE_F350's Avatar
RAMPAGE_F350
EBPV operation
Do any of you guys have the exact voltage the PCM sends to activate the coil for the EBPV? Thanks for your help.
Old Oct 25, 2005 | 05:55 PM
RAMPAGE_F350
Come on guys there has to be somone with Tech manual out there.
Old Oct 25, 2005 | 06:02 PM
Kwikkordead's Avatar
Kwikkordead
When I was researching my truck to see how to go about converting the EBPV to an exhaust brake, I tested for power at the plug to the solinoid. It's not a constant voltage. It's a pulse width modulated signal that makes the test light blink on and off about 4 times per second. I never bothered to measure the voltage after that. I went and got a 10 ohm ballast resister to drop the voltage down so I wouldn't burn out the coil. I don't know if it was necessary or not, but I was more comfortable running the solinoid that way because it was designed to be activated by a pulse width, not constant power. So the coil seemed to me would be a hotter wind than one that would be designed for continuous duty.
Hope that helps.
Old Oct 25, 2005 | 06:03 PM
Kwikkordead
What do you have in mind, anyway?
Old Oct 25, 2005 | 06:11 PM
RAMPAGE_F350
Well I did the EBPV mod on a relay with a rectifier diode going toward the PCM and a resistor toward the valve. Everything is working as it should,but I also hooked up a 5VDC LED toward the PCM to see when the PCM activates the valve.However, just like you said it the LED pulses.Just tring to get rid of the pulsing.
Old Oct 25, 2005 | 06:15 PM
Kwikkordead
Suggest moving the power supply for that diode to the side that powers the EBPV. I don't know of any way to get rid of the pulse, because that's what the ECU is putting out.
Old Oct 25, 2005 | 06:31 PM
RAMPAGE_F350
Thanks Kwik,its time to experiment.he he! I'm not happy unless I'm tinkering anyway.
Old Oct 25, 2005 | 06:50 PM
SpringerPop's Avatar
SpringerPop
Capacitor. Try starting with a 50uF. It filters those periods of no-voltage right out. The stored voltage will collapse quickly when there is no supply, giving you no false "on" indication.
You may have to play with the size of the cap, as I don't know the current draw for the EBPV actuator, and I did no math.
Pop
Old Oct 25, 2005 | 06:58 PM
Kwikkordead
Wow I never would have thought of that Pop. Great idea!
Old Oct 25, 2005 | 07:51 PM
RAMPAGE_F350
Thanks guys
Randy McKinney
Nov 17, 2013 12:34 AM
A/Ox4
Apr 11, 2013 06:36 PM
JethroF250
Mar 26, 2008 10:12 PM
vpofscc
16
Apr 14, 2006 01:22 PM
injun46
Nov 29, 2005 04:14 PM
