overdrive on/off switch doesnt work
Old Oct 24, 2005 | 04:28 PM
OfficerDangle's Avatar
OfficerDangle
i have a 99 f250 7.3 4x4 auto tranny, the switch is built into the end of the column, i have looked at the fuse panel under the steering wheel and there are no blown fuses, question is where else can i look for maybe a unpluged wire because when i bought the truck it didnt work. or a replacement, any help is appreciated thx.
Old Oct 24, 2005 | 05:59 PM
Casey's Avatar
Casey
The wires often break in the steering column, near where the column tilts. Take off the plastic cover and you should be able to get to it.
Old Oct 24, 2005 | 06:18 PM
SpringerPop's Avatar
SpringerPop
Try the information here:
https://www.ford-trucks.com/forums/s...d.php?t=421538
That may be your problem, too.
Pop
Old Oct 24, 2005 | 08:45 PM
OfficerDangle
how do i get the top plastic housing off the column, the housing for the ignition is the only thing holding it on
Old Oct 24, 2005 | 09:07 PM
ryaneverk2's Avatar
ryaneverk2
Well, to remove the ignition switch people usually stick a skinny screw driver or unfolded paper clip in the small hole to press a detent and remove the ignition. Perhaps if you did that, it would allow you to remove the top piece.
Old Oct 24, 2005 | 10:40 PM
SpringerPop
There are screws in the bottom piece. Take them out. The bottom piece drops off. The top piece is "finessed" off. Reverse to assemble.
You needn't remove the key cylinder assembly.
Pop
77_F150_4x4
May 13, 2014 01:36 PM
snakedoc
Dec 23, 2010 05:35 PM
Jackemupjoe
May 9, 2010 08:23 AM
climo
Oct 1, 2008 12:45 AM
beachrat
Electrical Systems/Wiring
Apr 30, 2008 07:16 PM
