Winter Grill
Old Oct 23, 2005 | 12:52 AM
rpenterics's Avatar
rpenterics
Winter Grill
I recently purchased an 89 F250 with the 7.3 in it, as winter is quickly approaching I was wondering if anyone on this forum knew where i could get a winter radiator cover for my truck. (I am refering to the leather type covers that go over the grill to restrict airflow into the engine compartment) your help is appreciated.
Old Oct 23, 2005 | 04:01 AM
bilder12's Avatar
bilder12
You could visit a local upholstering/vinyl shop and have them make one for you. Make sure it will open in the center to allow the clutch fan to operate properly.
Old Oct 23, 2005 | 11:56 AM
tdford's Avatar
tdford
If the t-stat is working properly you might not need the cover, especially if you normally pull a load. My engine ran cold for a couple of winters and I used the cardboard trick. When I changed the t-stat the problem went away. If you seem to be running cold it's also possible that someone may have changed the t-stat and not installed the genuine ford part. There is a big difference in how they work. The only way to tell is to pull the t-stat and if I did that I'd go ahead and put in a new ford part. I'd almost bet that will fix the problem but in the meantime a makeshift radiator cover can be made with peices of cardboard cut to fit between the grill and the radiator. Stick those behind your seat and wait and see if you need the cover.
Old Oct 24, 2005 | 07:32 PM
kidoo's Avatar
kidoo
I was just wondering, how cold is it running? Mine just sit close to the cold line, a little over, not even at the 1/4. I got a bra snapped on the grill many years ago and when I pulled the camper with a facing wind at about 10 F, the engine got a bit hot.
I wonder if I have the proper thermostat. Where should the needle be?
Old Oct 24, 2005 | 09:38 PM
Dave Sponaugle's Avatar
Dave Sponaugle
No use looking at the stock gauge and trying to figure anything, I think they are all different.
Mechanical gauge is the only way to know.
Old Oct 25, 2005 | 09:42 AM
kidoo's Avatar
kidoo
So what is the temperature sitting at say 75 F and no load.
Old Oct 25, 2005 | 12:31 PM
justblowin'smoke's Avatar
justblowin'smoke
Lund makes grill inserts tha snap on and look decant for like 70 bucks look in jcwhitney i have them and like em get the cold front ones but they also have stainless steel billet type ones too
barnhartred
Dec 14, 2013 09:19 PM
slowmans
Ford Truck Parts for Sale
Jul 20, 2013 06:16 AM
waumpuscat
Nov 12, 2011 12:25 PM
dsl_pwrd_ford
Oct 28, 2008 06:57 AM
86'f250
Nov 25, 2005 04:39 PM
