Grill Cover For Winter?
Old Nov 25, 2005 | 01:30 PM
86'f250's Avatar
86'f250
I was wondering where i could get a grill cover for my 86 f250 instead of using a piece of cardboard for these colder days in minnesota.
Old Nov 25, 2005 | 04:39 PM
Piffery1's Avatar
Piffery1
If the cooling system has the proper thermostat and antifreeze solution, why do you need to block the radiator? I thought blocking radiators went out with alcohol antifreeze. When I was in Northern Michigan all our vehicles had 120 VAC heaters either in the lower radiator hose (which I preferred) or mounted on the block in a "freeze plug" hole. We also had a heat pad under the battery. Of course, none is needed in NW Florida.
Keeghan98
17
Aug 29, 2023 01:05 PM
GHeTTo JOe
Nov 30, 2008 01:06 PM
75f-250
Aug 31, 2007 11:13 AM
lrd56
Paint & Bodywork
Aug 13, 2004 09:57 AM
rk5400
Sep 12, 2003 12:47 PM
