how yall doing heres my problem i have a 95 f-150 with a 300ci six its efi and i would like to rebuil the motor for performance only thing is i don't know where to find performance parts for it also i don't know what parts of other motors will work on it ei:302,351 ect, i would like to keep it fuel injection , any help would be appreacated thank you for ur time
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Peruse this list of Parts which includes manufacturers names.
300 H.P. @ 4600 rpm & 400 Torque @ 3200 rpm w/ a 10 to 1 C.R.
It idels @ 675 & is smooth as glass, a quarter was placed on top of the Valve Cover & it Did Not move Nor rattle.
Ross Pistons 4.060
Hastings Power Flex Rings .060
Federal Mogul Mains .020 Under
Clevite Performance Bearings Std.
Federal Mogul Cam Bearings Std.
Melling Torque Cam
Melling H.V. Oli Pump
Eagle H-beam Rods 6.300 2.100 Rod Journal
Crane Gold Race Roller rockers
ARP Main Stud Kit, Rocker Studs,
Fisher International Ballancer
Bore 4.060
Power Hone 4.060
Full P&P Intake & Exhaust
Performance valve job
Performance Balance job on Steele Crank w/ in 7 grams
Grind Rod Journals to 2.100
Plumb Intake for Heat via Water Pump
Deck Block to Square
Align hone to Factory specs
Deck block for Zero Deck
Offenhauser C Intake
Holley 1850 600 CFM
S.S. Borla 2 into 2 Header
