Performance tuning
Old Jun 26, 2012 | 07:01 PM
BIG_RED86's Avatar
BIG_RED86
Performance tuning
I have an 86 f250 with a 351 i just want to know if there are any aftermarket parts or just simply tuning tricks i don't know of that would really help my performance. Thanks
Old Jun 26, 2012 | 07:03 PM
cliffordingles's Avatar
cliffordingles
Really depend's on what the end out come is that you want...
It's a V8, you can pretty much do anything to it. Start with opening up the exhaust and intake, put in a little larger cam...
Old Jun 26, 2012 | 08:07 PM
ctubutis's Avatar
ctubutis
Do you need to pass emissions tests?
Old Jun 26, 2012 | 08:22 PM
garthneddy's Avatar
garthneddy
If it has the factory 2 barrel intake and carb then those would be the very first things i would switch out. That alone will make a notable differance in performance
Old Jun 26, 2012 | 09:15 PM
Gary Lewis's Avatar
Gary Lewis
An 86 351 should be the HO, which will have the Motorcraft/Holley 4180 4bbl carb and a warmed-up cam. You would have more performance with something like and Edelbrock Performer intake manifold, but the difference wouldn't be large. Probably the best thing would be to change out the cam to maybe the Comp Cams XE250H. And, true dual exhaust will help some, but only if you are really winding it up.
Old Jul 1, 2012 | 02:45 PM
BIG_RED86's Avatar
BIG_RED86
Thanks for the comments i will definitely look into the manifold and cam suggestions. And no i do not have to pass emissions testing
rattler1775
Aug 29, 2011 07:55 PM
mward69
Oct 7, 2008 04:37 PM
asmith6
Oct 10, 2007 10:46 AM
cruzin55f100
Sep 20, 2006 07:18 PM
