clunk on startup
Old Oct 21, 2005 | 03:01 PM
lifted_01_SD's Avatar
lifted_01_SD
clunk on startup
Hey i wonder if any of you guys ever hear of a PSD having a small not to loud single clunk on cold startup about 2 seconds of running , pop , then all is good. It still performs well and there is no smoke or bad starts just a pop. its never done it before and its bothering me. It does not do it all the time. What could this be. All fluids are good. Its a 2001 PSD auto 4x4 stock with 197567 on the clock, please tell me its not going to grenade. please help.
Old Oct 21, 2005 | 03:37 PM
dvfd12's Avatar
dvfd12
Does it sound like it comes from the right front?
Old Oct 21, 2005 | 03:57 PM
FrdTrkLvr's Avatar
FrdTrkLvr
I have the same problem and yes it does come from the right front. Any ideas.
Old Oct 21, 2005 | 04:04 PM
Fire Rooster's Avatar
Fire Rooster
Flapper valve for vents opening/closing depending on A/C being on or off. Turn A/C off start up truck and then, turn on A/c you will hear clunk later.
Old Oct 21, 2005 | 04:07 PM
FrdTrkLvr's Avatar
FrdTrkLvr
I'll try that. Thanks for the help!
Old Oct 21, 2005 | 04:15 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i have heard on here that it is the A/C compressor clutch....
but it perfectly normal but doesnt sound too good.
Old Oct 21, 2005 | 04:31 PM
tjbeggs's Avatar
tjbeggs
not the compressor! its the blend door in the heater system that is operated by vacum. when it gets enough vacum after startup it slams shut causing the niose you hear. so no worry it IS normal and is NOT your compressor.
Old Oct 21, 2005 | 06:03 PM
lifted_01_SD
ok thanks it does sound like its coming from the front right, it does sound like a dull thud, so its not in my motor.
Old Oct 22, 2005 | 12:15 AM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Mine does that every morning if I forget to turn the heater off.
Old Oct 22, 2005 | 02:45 AM
99bajakid's Avatar
99bajakid
is there any way to stop that? i hate it when my truck does it, maybe I should switch to decaf but it startles me sometimes. I can feel it throughout the floor board.
Old Oct 22, 2005 | 08:57 AM
Fire Rooster
Do not turn on the heat or A/C. That will solve it. But then you gota deal with sweaty wet clothes, or chattering teeth.
Old Oct 22, 2005 | 05:52 PM
jet2fan's Avatar
jet2fan
I always turn a/c or heater to off, then turn truck off. After starting motor,then turn on a/c or heater. That solves the problem for me,unless I forget to turn everything off before staring up. Good luck
