new engine
Old Oct 20, 2005 | 10:29 AM
4.9inline6's Avatar
4.9inline6
new engine
i recently bought a referbished 4.9 i6 for my 93 ford. i am in the process of swapping all the parts from my old i6 to the new one. once i get the whole bunch together and put back in, i plan to do new exhaust b/c the old engine, right before i took it out, was blowing wet oil through the exhaust- i figure it may be clogged up by now. what would everyone suggest. i want the best sound possible. should i do headers to straights? stock exhaust manifold to high-flow cat, then muffler? do i even want a cat? duals or single? also, the truck at one point had the exhaust redone to single exhaust (the old system rusted off). if single exhaust is what everyone would advise, do i need to get new everything or just muffler/cat or whatever? Thanks for any advice.
Chris
Old Oct 20, 2005 | 01:15 PM
optikal illushun's Avatar
optikal illushun
theres a good topic in the sticky called, "efi performance tips and tricks". pretty much lays out what the deal is whats best.
Old Oct 22, 2005 | 01:29 AM
Bdox's Avatar
Bdox
You do want the hi-flow cat. The efi exhaust manifolds are pretty good. Going large on the exhaust is helpful if you drive at high rpm, (more peak horsepower,) but for typical driving it's not necessary. If you are towing, climbing mountains, you might need that larger exhaust. There is a whole lot of very pricey exhaust parts out there, but your local muffler shop can upsize the exhaust using a half inch larger diameter pipe, high flow cat and muffler. Cheaper that way and does the job.
FarmTruck93
Feb 10, 2017 04:59 PM
MarkusUT6
Aug 17, 2012 07:09 PM
FordGuy85
May 5, 2012 12:08 PM
ErrorS
Dec 13, 2010 02:22 AM
trueblue_79
Exhaust Systems
18
Jul 21, 2003 10:46 PM
