98 Ranger 4L Engine squeel
Old Oct 20, 2005 | 09:43 AM
pill's Avatar
pill
My 98 Ranger has a loud pulsating squeel that seems to be coming from the area around the electronic ignition system. The squeel increases in amplitude with an engine speed increase, disappearing at revs over about 2500.
I've checked the obvious belts, pumps, alternator etc. They are not the issue.
The truck runs ok except for the noise. I do have an issue with P0171, and P0174 codes intermittently being triggered. I have not been able to find the cause of this either. I have checked / cleaned the MAF, IAC, EGR (its a California truck). I can't find any vacuum leaks and have replaced the PCV. The O2 sensors have been tested and are ok.
Anyone have any ideas?
Old Oct 20, 2005 | 12:46 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Originally Posted by pill
............. a loud pulsating squeel ...........
A vaccum leak would be worth looking for, especially on the lower intake.
Old Oct 20, 2005 | 01:29 PM
pill's Avatar
pill
I just took the throttle body off. The inside of the intake is coated with black stuff, from the EGR I guess. Reassembled and checked for leaks with starter fluid, couldn't find any. Like you say CowboyBilly9mile, I may have to remove the manifold, the forums seem to indicate an ongoing problem with this area.
The squeal, intermittent and pulsating sounds like a bearing being torn up. The only thing in the area would be the cam shaft, or possibly further back the oil pump drive.
I found a mechanic who works on engines, he seems to think it's internal, he didn't want to go any further, other than suggesting a teardown.
Thanks CowboyBilly9mile
Old Oct 20, 2005 | 08:18 PM
Rockledge's Avatar
Rockledge
Welcome to FTE!
A bad camshaft synchronizer could cause a squeeling noise. It's located in the back of the engine, near the fire wall, underneath the upper intake. The camshaft postion sensor (CMP) sits on top of it. One of those mechanic stethoscopes would help pinpoint the noise.
This thread talks about the CMP sensor and synchronizer on a 3.0L OHV engine, but everything is pretty much identical regarding the 4.0L OHV:
https://www.ford-trucks.com/forums/s...hreadid=202004
Old Oct 20, 2005 | 09:29 PM
pill's Avatar
pill
Wow, This sounds like the problem. I will investigate and let you know the results . thanks.
Old Oct 21, 2005 | 06:46 PM
pill's Avatar
pill
I looked at the cam shaft synchroniser, used a mirror, finally found it. It was buried a little too deep fpr me to tackle the job.
I took it to the Ford dealer, I don't know any private shops in my area that I would trust my bicycle with. They knew the problem right away. qoted me 400 to $500 fpr repairs. I took them up on it.
$481 dollars later, the squeal is gone, truck runs great. They charged me $219 for the shaft assembly. Did not change the synchoniser itself. $245 for 2.5 hrs labor. The gasket under the upper intake was also changed, included in the job. Hopefully that takes care of the CEL coming on.
Thanks Rockledge and CowboyBilly9Mile for your help. Problem solved.
nbtone
22
Jul 17, 2020 02:30 AM
rblaine9000
Feb 24, 2011 07:40 PM
rdeanw
1997 - 2003 F150
Aug 30, 2010 10:18 PM
DARK_HORSE
Oct 15, 2005 07:07 AM
