Tip:Sand Disk Backing Makes Great Putty Mixing Surface
Maybe I'm late to the party on this, but I finally had to buy new pack of sanding disks - the pre-gummed kind. I needed something small to mix a spot of body putty on and found those throw-away covers work really well. Whatever they are made of, the hardened putty just peels away from leaving a nice clean surface to use again and again.
Fiberglass Evercoat makes bondo boards that cost a whopping $2.50 and are flexible, so when the bondo dries you can bend it and the stuff will pop right off. Its also got a little hole so you can hold it like a painters easel. As for the bondo having the right ratio on cardboard, when the directions say "1/4 inch by 1/2 inch bead of hardener per golfball sized amount of bondo" I don't think the cardboard absorbing the .002 ounces of hardener will make a difference.
For anything that requires mixing, I use a piece of foot square 3/8" safety glass. I don't recall where I got it, but nothing really sticks to it. Body filler, putty, structural marine filler, nothing.
Easy to clean too... wipe it off and all that, and scrape off the one or two little pieces that stick with a one-sided razor blade.
