A/C problem
Old Oct 18, 2005 | 09:43 AM
fourwheeler88's Avatar
fourwheeler88
A/C problem
Hey guys i had a question about my truck (2000 psd cc sb) my a/c only works on high and not on low or medium. Is this some sort of relay problem or is it a fan problem? any help is appreciated....thanks in advance
Old Oct 18, 2005 | 10:09 AM
Kwikkordead's Avatar
Kwikkordead
You mean the blower fan?
Old Oct 18, 2005 | 10:14 AM
mech2161's Avatar
mech2161
Blower motor resistor. Next to the blower.
Old Oct 18, 2005 | 10:16 AM
fourwheeler88
im not sure but when i turn the ac on and turn the fan **** to low or medium it wont work but when i turn it to high it will work.... im lost on this
Old Oct 18, 2005 | 10:29 AM
mech2161's Avatar
mech2161
I tried to tell you what was wrong. The resistor works all the speeds except high.
Old Oct 18, 2005 | 10:38 AM
wilbur996's Avatar
wilbur996
Most likely as stated it is the blower motor resistor. The same thing should happen when the heat is on. The fan will only work on high. Try it on heat setting too. I do not know where it is located on your truck but the typical location is under the hood next to the blower motor on the heater box. Follow the wires from the blower motor and you will find the resistor. I think it is a 3 wire plug. It looks like a little plate with 1 screw holding it on. The resistors are on the inside side of the heater box so air gets blown across them to cool them off.
Good luck.
Old Oct 18, 2005 | 02:16 PM
Kwikkordead
That's what I was thinking, but was unsure if there is a resister or a different winding in the motor installed on the truck. Now I know.
Old Oct 21, 2005 | 10:07 PM
fourwheeler88
thanks guys for all the help. sorry i didnt reply sooner ive had the truck in the shop twice this week for the rear main seal leaking and i looked tonight and its still dripping!! well thanks to all that helped
mudslinger2
May 3, 2013 07:56 AM
bayous
Jun 15, 2011 10:42 AM
raleigho
Aug 5, 2006 05:28 PM
club van
Aug 3, 2003 12:58 AM
Boss_358
Jun 30, 2001 09:49 AM
