Sponsored by: Auxito
Help p0316 code
Old Oct 17, 2005 | 12:54 PM
yuenglag's Avatar
yuenglag
Help p0316 code
I have a 2002 F150 4.6 Truck was bucking when i tried to maintain speed . Did A code check came up with A mis fire in #8 cyl. changed spark plug and coil. Truck is running fine now ,But also during scan the code p0316 came up and is not documented. does anyone know what this code is ? (Auto zone thinks this is a dealer specific code?)
THANKS!
Old Oct 17, 2005 | 09:22 PM
bosshoss's Avatar
bosshoss
Its is a code for engine missfire noted on the first 1000 rpm on start up. How long did you run with the bad coil and plug? Have auto Parts place do a code clear, then re check for codes. You will have a p1000 code, dont worry it will clear on its own after you drive a little. Hope this helps. Good luck.
Dave Powell
Old Oct 18, 2005 | 10:23 AM
yuenglag's Avatar
yuenglag
I drove the truck approx 250 miles before I changed plug and coil .
Trapper30
General Automotive Discussion
Jan 25, 2015 08:17 AM
MStakes
Jul 5, 2014 11:59 AM
joesnogood
Feb 26, 2014 10:18 PM
dwbaily
Oct 1, 2013 09:24 PM
jpeloian
23
Oct 31, 2011 09:49 AM
