302 PS Bracket Alignment
Old Oct 15, 2005 | 11:11 AM
scottlane's Avatar
scottlane
The more I try to tighten up my newest purchase the more I find to do. This being my first 302 I don't have much experience of what should and should not be.
Case in point, the power steering bracket. I know that the original 390 in this '76 was swapped for the 302 (1970 I believe) that he truck currently has (I bought it from the original owner). I have not been able to get the squeal out of the belt. Well I found that the reason is that the bracket is at a slight angle. I am guessing that it was fabricated/modified to accomodate the pump. Are there different PS brackets for different years of the 302? I want to narrow my guessing down before I go hunting.
Another thing that I have found is that the auto shift linkage was too short so an extention was added to the end near the tranny. Shifts fine but I cant get my indicator lined up correctly. Can I get a longer (2") shift link?
Old Oct 19, 2005 | 11:15 AM
1975Ford's Avatar
1975Ford
Try finding a power steering bracket which include the power steering pump and hoses off a used truck which has a 302 cid engine. This should solve the bracket problem.
Usually, on the transmission shift linkage on the transmission. Block the tires, place transmission in neutral, now adjust linkage to where the shift indicator is located to neutral. If it doesn't line up, maybe refabrication of the transmission shift linkage will be required. I don't know much of what style or models of linkage will fit.
Old Oct 19, 2005 | 11:33 AM
scottlane's Avatar
scottlane
Thanks for the reply. I found one (and only one) 70s 302 in my local parts yard. As luck would have it, it was a loaded 72 Mustang whose motor had not been touched. I got the pump and the bracket off yesterday and will be getting them apart today. Looks like my 71 motor has a 78 pump and bracket. I can get things worked out now.
The shift linkage issue. I understand how to set it, the problem is I don't have enough adjustment. It's like this 302 sits back farther than the stock 390 and/or they changed to a C6 and the linkage was shorter. Their solution was to cut the adjustable end off of another shift link and bolt it on the end of this one. My "move" needs to be where the extension was joined. Never seen anything like this. It works and shifts but does not line up. Counting the shift movement has become very important I may be able to bend it but was hoping to hear from someone who has experienced a similar problem and found a successful solution.
Old Oct 19, 2005 | 03:59 PM
1975Ford's Avatar
1975Ford
Maybe fabricating a bracket which would adjust at the transmission, and does not flex much.
TBird Larry
Sep 23, 2014 02:37 AM
Brownie58
Aug 2, 2012 05:40 PM
PRIMERED79 SHORT BED
34
Jun 29, 2012 08:38 AM
98Stang
Aug 30, 2010 01:08 PM
popslide
Jun 13, 2008 08:43 PM
