Front Spindle Nut Torque
Old Oct 2, 2011 | 08:33 PM
390XR7's Avatar
390XR7
Hey can anyone tell me what the torque spec is for a 04 Sport Trac 2 wheel drive?I'm going to change the front wheel bearings and need to know what the torque spec is for the spindle nut when I bolt everything back up.
Thanks
Old Oct 2, 2011 | 09:24 PM
shorod's Avatar
shorod
Are you referring to the lower ball joint nut torque on the 4x2? If so, that torque spec is 133 Nm or 98 lb-ft.
The torque for the nut and pinch bolt is 55 Nm or 41 lb-ft, and the torque spec for the outer tie rod end is 70 Nm or 52 lb-ft. And while we're listing specs, the torque spec for the bolts holding the ABS sensor is 7-11 Nm or 62-97 lb-in.
-Rod
Old Oct 3, 2011 | 10:42 AM
390XR7's Avatar
390XR7
This is what I need to know.I need the spec for a 2 wheel drive.after doing alot of searching I've found tighten to 21 ft lbs back off 1/2 turn and re tighten to 17 in lbs is this correct?
Thanks
Old Oct 3, 2011 | 08:17 PM
shorod's Avatar
shorod
Ahh, yes. From the service manual:
Tighten the spindle nut while rotating the brake disc and hub. Torque nut to 23-34 Nm (17-24 lb-ft).
Tighten the spindle nut 175 degrees while rotating the brake disc and hub.
Tighten the spindle nut 2 Nm (17 lb-in) while rotating the brake disc and hub.
Install the following components:
  • Install the nut retainer.
  • Install the cotter pin.
  • Install the hub grease cap.
Effectively, what you found during your searching is correct (180 degrees would be half a turn).
-Rod
Old Oct 3, 2011 | 09:21 PM
steve(ill)'s Avatar
steve(ill)
Thats probably right. I have never used a torque wrench on a bearing nut on a 2 x 4 front end. The final test is AFTER you think you have it correct, make sure the hub turns very easly, even spin. IF you grab the disk top and bottom and try to shake it in and out, you should get a very minor bearing clearance "wiggle". It should not be tight, you need a few thousands clearance in the bearing to grow as it heats up.
DanK5
1997 - 2003 F150
Oct 16, 2016 11:23 PM
69ford99
1978 - 1996 Big Bronco
Nov 15, 2006 07:55 AM
Danny_Ocean
Mar 19, 2006 09:29 AM
