View Poll Results: What Method Do You Use to Rotate Your Tires
Front to back, same side.
20
45.45%
Forward cross.
13.64%
Rearward cross.
25.00%
Cross, include the spare tire.
0%
Whatever the tire shop uses.
11.36%
I do not rotate my tires.
4.55%
My tires rotate as I drive. What else do I need to know?
0%
Voters: 44. You may not vote on this poll
Tire Rotation Method?
Old Oct 14, 2005 | 05:34 PM
SpringerPop's Avatar
SpringerPop
When you rotate the tires on your Superduty, what method do you use?
Lots of theories on right and wrong ways to do it, some based on problems with radial tires when the they were first coming into the marketplace in America.
What do you do?
Pop
Old Oct 14, 2005 | 11:18 PM
wildbill1963's Avatar
wildbill1963
I could be wrong, but you should be doing it this way for rear wheel drive/4 wheel vehicles (w/o using the spare):
back to Front same side,
Cross Front to Back
Old Oct 15, 2005 | 11:32 AM
roaky81's Avatar
roaky81
I do the front to back since hearing/reading about keeping the rotational flexing on the sidewall/tread going the same way. Could be a bunch of cra-, but it works for me.
Old Oct 15, 2005 | 11:40 AM
LONEPINERON's Avatar
LONEPINERON
Being as I have 6 tires and wheels I do the cross including spare and thro #2 spare to right front. Works real good so far.LPR
Old Oct 15, 2005 | 01:18 PM
tjbeggs's Avatar
tjbeggs
i am a mechanic and all rotations i do are front to back same side. i do it because it works. rotation reversal and all that i have heard but i haven't seen or heard proof, but i have cross rotated before with snow tires to put the sharp edge digging and didn't have any probs.
Old Oct 17, 2005 | 09:09 AM
doc526's Avatar
doc526
Cross rotation is no longer a problem on radial tires. I use both cross and front to back methods.
Old Oct 17, 2005 | 09:47 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Do the dually guys rotate their tires? Cant say as Ive ever seen one with the dual wheels up front!!!lol
Old Oct 17, 2005 | 01:52 PM
doc526's Avatar
doc526
You can rotate dually wheels. On models that have steel wheels all around, you can just take and swap from front to rear. On models that have aluminum wheels,(wheels are specific to front and rear) you have to demount the tires, swap front and back and remount/balance. That is how we rotate duallys at the shop.
Old Oct 17, 2005 | 01:59 PM
qman's Avatar
qman
Front to back same side. I called BFG last year when I bought my A/Ts and asked them about the problem with switching direction and the guy said there is no problem. You can switch tires from one side to the other. Otherwise how would you ever be able to buy used tires?
Old Oct 17, 2005 | 02:07 PM
Kwikkordead's Avatar
Kwikkordead
I would if I could. The stems on my rims are rigid and stand up to the hole in the rim so it's easy to check air pressure. But it makes a tire rotation impossible with demounting the tires and I don't want to go through that!
Old Oct 17, 2005 | 07:55 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I've done front to back same side for nearly ever, because several years ago I had a tire slip a belt withing days of a rotation. Prior to that I crossed the fronts to the back.
Probably will go back to that next time....have a hard time keeping the shoulders square on the SD going front to back.
Old Oct 17, 2005 | 08:11 PM
wildbill1963
The key is proper air inflation, alignment and rotation to manufacturer specifications.
Old Oct 17, 2005 | 08:15 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i noticed my brand new tires (front) were cupping inwards. (the front of the lug was cutting (on the top). i was going to get a front end alignment, but my uncle said because of the design of the suspension and other stuff, that it would probably be like no matter what. so i took the left tire and put it on the right side, and it has re-cut the cuppling back smooth now. i guess just do it every 1000 miles or so and they will stay smooth. our 550 has max-tracs, and they are cut SOOO bad.. they are extremely loud too.
