Steering Feels Floaty?????
Old Oct 13, 2005 | 09:37 PM
bigexpo's Avatar
bigexpo
Exclamation Steering Feels Floaty?????
hey i forgot to put this in my other post but my steering wheel feels like it has to much play in it adn it feels like i dont have alot of control of the truck. should i replace the stering shaft etc. or what please help i dont wanna fly off the road
Old Oct 13, 2005 | 10:14 PM
silly34's Avatar
silly34
My story
B.
Old Oct 13, 2005 | 10:33 PM
bigexpo's Avatar
bigexpo
but i dont have lls i have coil springs.
Old Oct 14, 2005 | 08:35 AM
PaulC's Avatar
PaulC
Check the tire pressure on all four tires and adjust them to the pressures found on the driver's door sticker. See if it impacts steering feel.
Old Oct 14, 2005 | 09:13 AM
projectSHO89's Avatar
projectSHO89
In addition to checking/adjusting tire pressure...
Make sure there's no free play in your wheel bearings also...
Inspect your tie rods, pitman arm, drag link, and ball joints...
Make certain your tires are appropriate for a light truck and are not passenger car or touring tires.
Steve
Old Oct 14, 2005 | 04:24 PM
Trucker22's Avatar
Trucker22
Idler Arm
All good advice---on my 2000 Nav the idler arm was totally shot at 40K----check it=-=pass side attached with huge bolts to the frame---have someone move steering quickly left to right while you are underneath watching and feeling---mine was moving a good quarter to half inch---AND it's one of the few front end parts that has a grease fitting and had been greased! Go figure. I'm not sure that Idler arm could also be called drag link? Just not sure but if you look on the pass side it's the arm that holds that side of the steering linkage up---drivers side is the pitman arm. Good luck
Old Oct 14, 2005 | 06:44 PM
bigexpo's Avatar
bigexpo
well before i go under the truck i wanna ask, are these trucks sopposed to handle that way i mean it doesnt feel as tight as my moms chrysler sebring but it just feels a little looser than that. i just started driving last week so i havnt experienced a whole bunch of cars nor another expedition. i did drive my dads blazer which had pretty nice tight steering but idk , so do these trucks just handle that way becuase they are so big, adn can i buy somehting or replace some parts like the sway bars or anything?
Old Oct 14, 2005 | 11:47 PM
PaulC's Avatar
PaulC
Your '99 should have tight, almost twitchy steering. Have someone check out the front end looking for worn components.
KCTDad
6.7L Power Stroke Diesel
Feb 17, 2017 10:46 PM
panic
Oct 6, 2016 01:38 PM
cummins cowboy
18
Mar 4, 2012 01:25 AM
xjcamaro89
2004 - 2008 F150
23
Jun 28, 2011 11:46 AM
Frankievespa
Jan 31, 2011 07:43 PM
