wiring through firewall
Old Oct 13, 2005 | 07:35 PM
trumpboy77's Avatar
trumpboy77
so im doing a few mods that require wiresgoing through the firewall. I don't want to just drill a hole and then two months down the road have problems cuz my firewall cut my wire in half. do you know where I can find those rubber things that go in a hole to protect the wires?
Old Oct 14, 2005 | 12:06 AM
Franklin2's Avatar
Franklin2
You should be able to go to the HELP! section of the auto store, and they usually have some grommets for PCV valves that will probably work, depending on what size hole you make. You might try the hardware store too. They may have a selection of grommets.
Old Oct 14, 2005 | 12:07 AM
ford390gashog's Avatar
ford390gashog
napa sells them for .88 a bag they are push in grommets
whalerron
Jul 3, 2016 09:36 PM
06SD250
Oct 10, 2010 05:17 PM
Big Ruth
Jul 5, 2010 07:23 PM
olelepoint
18
Dec 15, 2009 08:44 AM
tip49
Aug 21, 2007 02:30 PM
