Sponsored by: Real Truck
Firewall wires?
Old Oct 9, 2010 | 06:53 AM
06SD250's Avatar
06SD250
Firewall wires?
Any suggestions as to where to run wires through the firewall for my strobe light kit on an 06 f250?
Thanks
Old Oct 9, 2010 | 07:19 AM
SlowGTA's Avatar
SlowGTA
Super Duties have what are called "customer access wires" already installed. There are four wires, one end of each is by the master cylinder under the hood and the other under the dash. they are there to allow you to hook up your own accessories with out haveing to penetrate the firewall.
Here's a link to a post with i picture:
https://www.ford-trucks.com/forums/9...t-cut-off.html
They are also called "pass through wires" or "blunt cut wires". A search will give you a lot more reading on them.
Old Oct 10, 2010 | 05:17 PM
06SD250's Avatar
06SD250
Thanks, that is good to know. I ended up just running everything through an existing hole as I needed to run the wires for the lights as well as the power wires, but I will use the customer access wires at some point.
Tmarshallg
Jul 28, 2017 04:04 PM
Flyview
Jul 17, 2017 12:02 AM
COsby
Mar 8, 2017 06:40 PM
kindorotten
24
Aug 21, 2016 10:18 AM
fatheroftwo
Jan 16, 2016 12:22 PM
