'98 Ranger XLT 4x4
'98 Ranger XLT 4x4
Hey Y'all,
New to the group and the truck. Just got it, '98 XLT Extended Cab, 3.0 with about 77,000 miles. Had to replace right axle and hub/bearing, as well as both front hub 4x4 actuators (sp?). I'm also becoming concerned that the automatic transmission (4spd) is slipping. Esp. when starting out cold, it seems to slip some, not so bad when it's warmed up. Anyway, I'm wondering if the transmission is prone to failure on this model. Hope I didn't get myself into the wrong truck...
Thanks for any input you may have on this truck.
Frank R
Frank R
Ken, Thanks for the tip about the hub, I missed that.
I changed the trans filter and fluid when I got the truck, didn't seem to make any difference. The fluid wasn't terribly dirty, but probably hadn't been changed in a while, if ever. The concern I have is that it seems to slip in first when cold, but it may be "normal". I won't bring it to a trans. shop, 'cause they only exist to sell trannys, and the Ford dealer charges 2 hours for a diagnostic, after which I suspect they'll tell me the same thing as the tranny shop. If I knew that these transmissions are notorious, then I'd feel better about replacing or upgrading.
Frank R
Frank R
fp_5
03-18-2009 08:46 AM
Frank Lang
05-25-2005 02:20 PM
