4R70W compatibilty
Old Mar 17, 2009 | 11:02 AM
fp_5's Avatar
fp_5
4R70W compatibilty
A friend of mine has a '97 F150 4.6/4R70W. The transmission is slipping so I'm looking for a used replacement( I'm designated mechanic, which means I do work for free! almost). I did some searching on this forum and couldn't find conclusive advice on what year donnor truck/transmission I can look for. I have a lead on a '96 4R70W that was mated to a 5litre. Will it work?
I've also read that the wiring harness changed after '97 so I should be looking for 97 and older right? Are there any other differences I should be aware of? As an example when I did my own E4OD I had to ensure I got one that the replacement could take a speedo cable speed sensor in the tail shaft.
Any help or a push in the right direction would be great.
Frank
Old Mar 17, 2009 | 09:01 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The 5.0L and 4.6L have different bolt patterns. They won't interchange.
Old Mar 18, 2009 | 06:41 AM
fp_5's Avatar
fp_5
thanks Mark, I was told the AODE/4R70W had removal bell housings which I thought was odd.
Do you know what year trucks would be a direct swap? Wreckers have it as '97 only. Which again is odd since this transmission is available in other years behind a 4,6.
Frank
Old Mar 18, 2009 | 07:38 AM
fp_5's Avatar
fp_5
I had a chance to test drive the truck this morning. It drove great , plenty of power, shifted smoothly both up and down,.....until 10 minutes later, it warmed up then nothing, it was like being in neutral. I shut the truck off waited 5 minutes, started it up again and made it a hundred yards down the road before I couldn't go any more. Did this to get home, checked the fluid and it was brown and burnt! Any chance this may be a Torque converter issue only? I've never had a transmission fail like this, operating fine when cold then nothing not even reverse.
Frank
Old Mar 18, 2009 | 08:46 AM
Mark Kovalsky
They do not have removable bellhousings.
There is no chance at all that it's a torque converter problem.
fp_5
1997 - 2003 F150
18
Aug 6, 2016 08:42 PM
dbreckman
1997 - 2003 F150
Aug 3, 2015 09:17 PM
moparlover
Oct 30, 2014 10:02 PM
brianb07
1997 - 2003 F150
Dec 18, 2008 08:49 PM
Schwersinske
1997 - 2003 F150
Sep 4, 2007 08:33 PM
